Sonar help needed
Hi all:
I'm having some trouble with to MB1200 sonar on my quad. No matter where it's mounted on the quad or how high/where it's pointed, the only value in the CLI test is 675 cm.
My quad is the stock 3DR built and configured by Udrones (850 motors) running ArduCopter v2.3.
I made sure the box is checked in the Hardware tab to enable and XL-EZ0 is selected as the correct Sonar.
Ran the test in CLI with the sonar mounted to the quad as well as holding it in my hand pointing it at different distances. Made no change to the value displayed.
Attached are the params currently loaded.
Thanks for any help out here :)
- Jason
params_3-10-12.param
  • Did you try to measure the analog voltage output of the sonar? Does it change when you point your module to different objects?
    Maybe you have a defective unit.
  • Are you using the sonar for altitude or collision avoidance?
    If you are sending out sonar "pings" horizontally, the prop "down wash" is going to screw with your ranging, the faster the air flow across the sonar path, the further away an obstacle will appear.
    Same goes for pointing straight down.
    Remember you are "stirring up" the medium you are trying to use to transmit your ping pulse.
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
