Sonar mounting
Have had no luck at all with sonar, but being an idiot, I am not giving up. I just bought one of the higher end Maxbotix sensors that I have been told handle noise much better and am trying to figure out how best to mount it on my quad. I know we are supposed to keep it away from ESCs and the FC - I assume this means keep it away from the wires to the motors from the ESCs as well? I have a bit of a logistics issue since the quad I want to put it on has a folding frame so any permanent mount that bridges the arms won't work.
What have others done?
  • Hello, this is Tom Bonar from MaxBotix Inc.
    I have seen that you are having problems with mounting one our sensors on your multi-copter.  We have recently done testing of our sensors on quad-copters for mounting and which sensors are the best for quad-copter applications.  After engineer testing, it has been determined that the best sensors for use on a mulit-copter are the MB1240, MB1340, and MB1242.  Other sensors will work, but these sensors have the best performance with all the interference that quad-copters can create.  These interferences include: air turbulence, electrical noise, and acoustical noise created by the quad-copter propellers.
    It is recommended when using our sensors with quad-copters to use a shielded cable such as our MB7954 http://www.maxbotix.com/Ultrasonic_Sensors/MB7954.htm and a power supply filter such as our MB7961 http://www.maxbotix.com/Ultrasonic_Sensors/MB7961.htm.  The MB7954 shielded cable helps protect the signal the sensor outputs from EMI that can be caused by other electrical components on the quad-copter such as the motors.  The MB7961 helps stabilize the power that is supplied to MaxSonar sensors.  Supplying clean power to the sensor is required for best sensor performance.  Conversely unclean power can negatively affect the sensor’s range readings.
    In the next several weeks, we hope to finalize a report of our testing and post it on our website as an article (including sharing on DIY Drones).
    Please let me know if you have any questions.
    Best regards,
    Tom Bonar
    Technical Support
    of MaxBotix Inc.
    Phone: (218) 454-0766
    Fax: (218) 454-0768
    Email: thomas@maxbotix.com
    Web: www.maxbotix.com
    Technical support and sales are subject to
    the terms and conditions listed on our
    website at http://www.maxbotix.com/ MaxBotix,
    MaxSonar,EZ0, EZ1, EZ2, EZ3, EZ4, AE0, AE1,
    AE2, AE3, AE4, WR1, WRA1, and WRLA1 are
    trademarks of MaxBotix Inc.
DIY Robocars via Twitter
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Monday
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Monday
Monday
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
Jul 4
Jul 4
