Sony QX100 camera in fixed wing, control from Pixhawk
I am new in the community, I want to thank you for sharing your knowledge in the forums.
I am working to mount a Sony QX100 camera to a fixed wing, but I have not managed to remotely control the camera.
I have read many comments about the connection with this camera. Using Raspberry PI or modifying the camera, in this regard I have not found information on how to modify the camera, I understand that you have to solder some cables internally, can someone from the community help me do this? or if you know of a tutorial to modify the QX00, I will be very grateful.
  • Thank you very much for your comments.
  • Hi Raul
    it's not that easy to give advice as your project goal,
    budget and priorities all will have impact.
    I can give you only an idea from what I did until I had
    to pause some two years ago. Legal issues came up blocking
    the way I like taking surveys.
    Within this forum 3-4 years ago a lot of great discussions
    took place. It will be time consuming but some basic ideas
    are still valid.
    I ended up with a used Sony NEX-5R with a Sigma 30mm f/2.8.
    For my low budget this $250 was a great invest.
    On my 2m plane the cam is taking about 3000 pics in an one hour
    flight. Its dimension seems to be similar to the M100.
    There was a discussion that indirect trigger like IR is not
    precise enough for high quality geo ref. I modified the cam
    to get direct access to release the shutter button. If this
    is an issue for you take care or use IR for trigger the M100.
    Your EOS M100 may be fine. With a prime lens you will be
    around 500gr. It seems that your plane doesn't have an issue
    with that.
    I don't see any other blocking point for the M100. But this
    comes only from looking at the data sheet.
    HTH
    Wolfgang R.
  • Thanks Wolfgang for the advice.
    I think I will buy a Canon camera, if you know of these cameras, I am in doubt about buying a Canon EOS M100 or Canon EOS M3.
    The EOS M3 has support for CHDK, but it is very heavy, while the EOS M100 weighs only 300 grams, but I think it has no support for CHDK ... or at least I think, if you can install the CHDK here would be great.
    According to your experience, which camera do you recommend for Pixhawk?
    wrostek said:
    Hi Raul,
    I do not own an QX100 but have a remark to it.
    I see that it is limited to 1/1600s shutter speed.
    From my experience on a fixed wing and the QX100 sensor resolution
    you should be careful about blurred images. Before you invest a lot of
    effort in the trigger be sure this will not block you later.
    Wolfgang R.
    I am new in the community, I want to thank you for sharing your knowledge in the forums.I am working to mount a Sony QX100 camera to a fixed wing, bu…
  • Hi Raul,
    Wolfgang R.
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
