Sony QX100 camera in fixed wing, control from Pixhawk
I am new in the community, I want to thank you for sharing your knowledge in the forums.
I am working to mount a Sony QX100 camera to a fixed wing, but I have not managed to remotely control the camera.
I have read many comments about the connection with this camera. Using Raspberry PI or modifying the camera, in this regard I have not found information on how to modify the camera, I understand that you have to solder some cables internally, can someone from the community help me do this? or if you know of a tutorial to modify the QX00, I will be very grateful.
  • Thank you very much for your comments.
  • Hi Raul
    it's not that easy to give advice as your project goal,
    budget and priorities all will have impact.
    I can give you only an idea from what I did until I had
    to pause some two years ago. Legal issues came up blocking
    the way I like taking surveys.
    Within this forum 3-4 years ago a lot of great discussions
    took place. It will be time consuming but some basic ideas
    are still valid.
    I ended up with a used Sony NEX-5R with a Sigma 30mm f/2.8.
    For my low budget this $250 was a great invest.
    On my 2m plane the cam is taking about 3000 pics in an one hour
    flight. Its dimension seems to be similar to the M100.
    There was a discussion that indirect trigger like IR is not
    precise enough for high quality geo ref. I modified the cam
    to get direct access to release the shutter button. If this
    is an issue for you take care or use IR for trigger the M100.
    Your EOS M100 may be fine. With a prime lens you will be
    around 500gr. It seems that your plane doesn't have an issue
    with that.
    I don't see any other blocking point for the M100. But this
    comes only from looking at the data sheet.
    HTH
    Wolfgang R.
  • Thanks Wolfgang for the advice.
    I think I will buy a Canon camera, if you know of these cameras, I am in doubt about buying a Canon EOS M100 or Canon EOS M3.
    The EOS M3 has support for CHDK, but it is very heavy, while the EOS M100 weighs only 300 grams, but I think it has no support for CHDK ... or at least I think, if you can install the CHDK here would be great.
    According to your experience, which camera do you recommend for Pixhawk?
    wrostek said:
    Hi Raul,
    I do not own an QX100 but have a remark to it.
    I see that it is limited to 1/1600s shutter speed.
    From my experience on a fixed wing and the QX100 sensor resolution
    you should be careful about blurred images. Before you invest a lot of
    effort in the trigger be sure this will not block you later.
    Wolfgang R.
    I am new in the community, I want to thank you for sharing your knowledge in the forums.I am working to mount a Sony QX100 camera to a fixed wing, bu…
  • Hi Raul,
    Wolfgang R.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
