Standalone accelerometer vs AHRS
Hello,
As a learning project - I'd like to build a PID stabilized see-saw (DC motor with a propeller on each end).
At the center of the see-saw teetering axis I need an inclination sensing element.
Do you think a fully featured AHRS is required or a simple accelerometer will do?
  • It should work
    Other methods may be:
    - fixed magnetometer - pivoting magnet in the center.
    - ultrasound sensor measuring distance between one arm and the ground..
    And if it's slightly off-balanced you can try to spare one motor/propeller :D
