I have been successfully flying a DJI Flamewheel F550 with a Naza controller, DJI stock motors/ESCs, etc for about a year now.  I love it.  However, I'm interested in autonomous flight utilizing waypoints and flight planning software.  Because of that, I'm thinking of retooling the hexarotor to APM or Pixhawk.  Can anyone point me to write-ups or posts that get to the ins and outs of this issue?  There are many feature comparison posts but none that I can find that outline the process of making the switch.  I'm particularly interested in what equipment I can repurpose vs. replace in order to understand the financial committment.
Cheers,
Paul
  • You should be able to repurpose everything except the NAZA, GPS, and PMU. It's been some time since I did mine, but I also have a 550 that I changed over to Pixhawk. You'll have to change motor rotations to match the Pixhawk output, but it should be easy. Just attach the 3DR power module to the battery leads, and run everything else through the 550 PDB. You shouldn't need the 3DR hexcopter PDB. Remember to remove the 5V power wire from each ESC, as you don't want to overpower the Pixhawk. And always look over the wiki to learn more.
    copter.ardupilot.com
    EDIT: Speaking of the wiki, I found this guide for setting up a 450 on there:
    http://copter.ardupilot.com/wiki/common-appendix/pdf-guides/ ;
    • Which line is the 5V power wire in the DJI ESC?
    • Thanks a bunch Mike!
  • Hi Paul,
    please could you tell me if you ever found a solution to this problem? I am facing the same issue.
    /A
    • No responses via this forum I'm afraid.  I am in the process of doing this project but I've been making pretty slow progress.  My primary research right now is whether I can run the 6 stock DJI ESC's (and DJI stock motors) into the 3DR Hex Power Distribution Board.  I am not sure what the voltage/amperage is coming out of the Pixhawk to the Hex PDB and whether that supply will be enough to support the ESCs/motors.
  • this pixhawk info graphic of  Jethro Hazelhurst might help.
    • Thanks Jay.
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
RT @SmallpixelCar: Today’s race with @a1k0n at @diyrobocars We both decided jumping over the wall was the way to break the 11s lap time. Th…
Aug 14
