TF02 LiDAR for drone height fixing
I forwarded this part here. Its a very cool LiDAR drone height fixing and terrain following
3691347945?profile=original
TF02 is a single-point ranging LiDAR, used by drone for measuring the relative altitude from the ground, ensuring the stable altitude. It is available for the following flight control brands: Pixhawk4, APM, TopXGun, EFY Technology, JiYi, aiAero, DAISCH, etc. TF02 has the following features:
<iframe width="560" height="315" src="https://www.youtube.com/embed/OHZHhBZF2SE" frameborder="0" allowfullscreen></iframe>
Distance Measurement Performance:
1.       Longer indoor and outdoor measurement range (indoor: 22m; outdoor: above 10m);
2.       Lower noise. Almost no abnormal data within effective range;
3.       Sound signal discrimination algorithm for identification of abnormal data;
4.       Higher repeated accuracy of distance measurement
Overall Performance:
1.       Higher protection level, up to IP65;
2.       Pesticide corrosion resistant, with special enclosure material capable of resisting corrosion of most of the pesticides;
3.       Work normally even with optical window being contaminated by dirty water, sludge and other pollutants;
4.       Shock resistance. Unique design makes it more solid, shock resistant and infrangible;
5.       Additional function of bootloader to facilitate further software upgrade;
  • Where can I find installation and configuration instructions?
