The Best Mounting Method Yet!
Ok Guys.
Hope this helps someone...
I recently tried to get the best vibration mounting i could to elliminate the vibes as much as possible for the flight control board. The results are pretty amazing and it also works for things like mounting a go pro.
The logs are added so you can see the accelerometer vibration graphs etc.
Its a pretty simple method involving a free floating plate with the control board on attach from the 4 corners using some elastic. The elastic is the same as that used in coats and im pretty sure its called elastic cord but not too sure.
Heres a video explaining it...
https://www.youtube.com/watch?v=_R-6gRRQA8M
Thanks Tom
Parts used as requested:
- 2.5mm stand offs - http://www.ebay.co.uk/itm/230593061461?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
- 2.5mm elastic cordhttp://www.ebay.co.uk/itm/BUNGEE-SHOCK-ELASTIC-CORD-2-5MM-WIDE-AVAILABLE-IN-BLACK-WHITE-DIFF-LENGTHS-/171025124140?pt=UK_Crafts_Sewing_Supplies_MJ&var=&hash=item27d1e44b2c
2013-04-20 14-06 23.log
  • Nice, it would really have helped if you posted links to where to get the parts you used .
