The new multi-aileron option
I am having problems with the new Multiple Aileron Channels option. It works by radio control but when I tilt the airplane the APM controls the left aileron (channel 1) but not the right aileron. I have tried turning on channel 5 and 6 and it does the same thing. Radio calibration is good and it works perfect in the manual mode. Is there some other parameter that I need to set?
Has anyone else tried this new option?
  • Doug
    Anyone who try new code need a failsafe in case of hang, at least I need that.
    Also hw can freeze for external problems like bec going under  a certain voltage for a second.
    The important si being aware of limitation, thing that is not pointed anywhere in the wiki.
    apm2 is told me to have a better failsafe solution than mux, full ppm sum rerouted directly.
  • wiki is wrong this is maye the 3rd time I say that.. you should set rc5 = 4 not 1 that is passtrough.
    it has no hw failsafe, only sw. is apm reboots you lose tha 2nd aileron
    I have flown with the two aileron option, as well as the flap option.
    What version of the code are you using?
  • Have you seen this page from the manual?
