Hello,
i was having a good time playing around with the mission planner and learning how to give commands and get the right results. Well i decided to try out the fail safe return to home feature by pressing the bind button on my transmitter while flying ( turns out no the best decision haha ) anyway the plane let off the throttle at that point and i was not fast enough to recover. I have the throttle fail safe setup in the apm to the stock 950ms and when i switch off my transmitter it goes to 943ms, being a newbie to this i figured it was set correctly and i would have no problem if i lost signal. Are there any other settings i am missing to make the return to home work?
I just checked this in the simulation, flight gear was the only one i can get to work. When i am in auto mode and switch off the tx it goes into manual mode. When i am in manual, stabilize or fbw-a and turn off the tx it goes into circle mode, why is it not going to rth mode? any help is appreciated
just going through my setup on the mission planner and when i bound the radio to the rx using the lowest throttle ( 929ms ) i also had the flight mode switch in manual mode. Do i need to bind it in stabilize or auto mode for the rth to work properly? or do i need the rth setting on my mode switch and make sure its active when i bind, as well as having the throttle below 950ms.
