Thrust issue
Hello all,
I have built an v-shaped octo-copter, with a 5000mah, 35c, 3s battery, 12gauge wire running from the center out to the arms, where I split the 12 gauge into 4 smaller gauge wires to go to the escs.
I have 10x45props with Motor AC2830-358, 850Kv from 3DRobotics, using 20amp escs. At the time, they were specified to provide 433grams of lift at 50% and 1095grams at 100%.
I have checked and double checked the prop directions, motor directions, and redone the esc and radio calibration.
My copter, all up weighs 3500g. A little heavy, but even with conservative numbers, this suggests I have a factor of two on my thrust.
While I start getting some lift at 50%, I go to 100% throttle and still barely get off the ground. Some basic math suggests I have 8*1095g=8760g of thrust at that point. Even using the more recent specs on the 3dr site of 880g -> 7040g of thrust.
I logged the motor outputs, confirming they go to full power, and suggesting I should be getting plenty of lift.
Could there be something wrong with my power distribution setup? Should I go to 4S? My props have about 1" of clearance between each other, am I losing thrust due to proximity? Soldering together 12 gauge wires, I used a fair amount of solder; is that an issue? I've attached a picture of the 12 gauge wire as it arrives at an arm, and the split into 4 plugs for the escs.
I've looked at other setups, and it seems to me that they are in similar weight/thrust setups. Even the 3DR hexa, using the same motors, takes off with 3000gram all up weight.
Any insight would be helpful.
Thanks,
Bart.
DIY Robocars via Twitter
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
RT @SmallpixelCar: Replaced AGX Xavier with @NVIDIAEmbedded Jetson Xavier NX. Now both cars look fast and clean https://t.co/jlcoY2EjZf
Apr 25
RT @chr1sa: Yesterday we had a record number of competitors (36) in our monthly @DIYRobocars virtual autonomous car race. We kept it going…
Apr 25
Apr 16
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Apr 11
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Apr 11
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Apr 11
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
