Tricopter Yaw reverse
I built a tricopter based on the titan frame, APM2.6, TGY-390DHM servo.
http://www.fortisairframes.com/titan-tricopter-frame-kit/
http://www.hobbyking.com/hobbyking/store/__11627__tgy_390dmh_high_performance_mg_digital_servo_extra_strong_5_4kg_11sec_22_5g.html
First, the servo was the correct direction when using the controller but the APM corrected the wrong way, causing it to spin.
Not reading the directions, i then reversed RC4, and then the APM held yaw properly, but the controller was now reversed.  so i reversed the controller and everything now works.
So i had to rev RC4 and rev channel 4 on my TX.
The question came up when i read the directions and it states to reverse RC7.  Why is that?  i know the servo is connected to output 7, but i thought RCx were the input channels?
Did i fix it the improper way?  If i rev RC7 will that not mess with channel 7 options?  Why did i need to rev rc4 and channel 4 on my tx to fix the servo operation?
  • Your description isn't really clear on how you've hooked up your system. Unless you do APM remapping, output 1 is the front right motor, output 2 is the front left motor, output 4 is the rear motor and output 7 is the yaw servo. I think you mighty be confusing your input RC channels with the output channels. The channel 7 options apply only to the input side.
    Depending on the specific brand of servo and the way it's mounted, you may have to reverse RC7 in the APM and/or your RC transmitter's yaw output. You might have to reverse both, or only one. You won't really know until you start testing. The RC transmitter is easiest, as you can see how it tilts the yaw servo (Note that you are NOT reversing the channel 7 RC output, you are reversing the yaw channel!!). But you won't know whether or not to reverse RC7 in the APM until you just try and hover and see if it spins.
    • Thanks, i think my confusion is the way things are labeled.  The instructions refer to the outputs as "RC1-8" and mission planer/firmware labeled the inputs RC1-xx.
      This line here caused the confusion:
      (*Tricopter note: If the direction of your tail servo is going the wrong way in response to yaw then set RC7_REV to -1 (from 1), you may also need to then reverse your transmitter rudder channel as well.)
      on this page:  connecting-your-rc-input-and-motors
      My setup uses " stock" input channel settings and motor outputs.  (channel 4 is yaw)
      Thanks for clearing that up.  I guess in this case reading the instructions only confused things :)
      • Confusion is understandable. tricopters are funky to start with, then there's the problem of possibly having to do reversals of the yaw servo....or not. I usually don't attempt a full liftoff to check the correctness of the APM. That could end up badly.  I just barely start it to lift and see if it starts to rotate on me. If it does, then I know to reverse the APM's output for RC7.
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
