Hi All,
Just letting you know that we have developed a light weight (<150gr) GPS box ready to plugin with any drone and camera system to provide up to 1cm+1ppm positioning accuracy for captured photos.
This enables drone operators to turn their drone to a highly accurate aerial surveying unit without need for expensive field work or ground control points collection. It tracks all current and upcoming Global Navigation Satellite System (GNSS) constellations and satellite signals including GPS, GLONASS, Galileo, BeiDou and QZSS. The system has been successfully tested on manned and unmanned aircraft and is an affordable ideal plugin for individuals, mapping companies or drone manufacturers.
Cheers,
Adam
Hi Adam,
Interesting. So, more options will available to build hi accuracy UAV. I am watching Reach from Emlid and Precis from Tersus-GNSS. Do you have link to your product web?
@Tersus-GNSS, you have an interesting RTK solution for UAVs which is great for short range flights. What we offer is a PPK solution for long range flights, i.e. it doesn't need real time base station correction transmission. It comes with a custom post processing software or optional online post processing service. Our solution is part of a proven turn-key airborne mapping and photogrammetry system which can be used on any unmanned vehicles as well, please check out www.geomatics.com.au for more details.
Hi Adam,
sound exciting. Such a device might be interesting for our application. Can you give us some more details about it and where we might be able to get it?
Cheers, Pascal
Hi Pascal,
The technical specification of the OEM receiver by itself can be found here
You can contact adam at geomatics.com.au and describe your application, payload and camera type to get a quote.
Cheers,
Adam
