Hello, I have been attempting to build and program an Ardurover for a few months now, but I seem to be encounter numerous problems which not many others seem to be encountering. The first and primary issue is the fact that I cannot achieve a link between the APM 2.5 and the mission planner when using the ArduRover firmware. It works with other firmware, but not for the ardurover. It initiates the connection, gets parameters, then fails at the last second before connecting. I also have been having trouble with getting my transmitter to connect to the receiver sometimes. It can be hard to replicate things because the way the mission planner program and the radio system have been acting are very inconsistent, working at one point, but failing to work at another for no obvious reason. Is there anyone who could give a little guidance who has successfully done this before? Any help is appreciated.
@Austin,
I found that the ArduRover2 v2.20b code did not interface well with the latest version of the MP. I do have the msi for MP 1.2.13 that works well with v2.20b if you would like to try it. However the new ArduRover2 code is much improved compared to v2.20b.
I suggest, if you have not already, join the ArduRover User Group and try out the ArduRover2 v2.30 alpha code that is on the ArduRover User Group Comment Wall http://www.diydrones.com/group/ardurover-user-group
TCIII
