UAV platform for high mountain prospecting
Hi All, I am new to the site, and interested in fabbing up a drone to help me locate lost mines in the high rockies, mostly above the tree line. This will require a platform that can operate up to 13,000 feet, though that will only be 200 feet over the ground surface. I want to stay as close to the ground as possible to maximize image resolution, and will be using software to generate 3D mosaic maps of my search areas.
I am currently looking at using the Zagi flying wing for a platform, but not sure how it will operate at high altitudes. I love the swinglet cam design at SenseFly, but way too expensive. Anyone know what camera they are using, or know of an ideal camera for this application? I understand Cannon has some nice "hacking" software, but wonder if any of you have input on camera or platform for high altitude use?
  • I have taken delivery of an X8 flying wing, and in the process of composing a parts list. I am going with APM 2.5, with best GPS I can buy, air speed sensor, the works. I am planning on incorporating both live video and downward photos for mapping. However, I am curious if anyone has any suggestions for a sensor system that could see through vegetation and record only the soils surface, or give me high resolution thermal imaging?
    Just for my own education, I have been reviewing available technologies, including FLIR, SAR, AGPR, etc. I would like to eventually be able to run thermal imaging if the OTS technology has a small enough system with enough resolution. I am interested in making this drone as valuable as possible for prospecting. But I understand the available imaging technology may not be advanced enough to pull off with a small RC drone.
    If you know of systems such as these that would work with the X8, let me know. I am doing my own research, but would like to get as much input as I can.
  • I am up in CO prospecting this week, and I gotta say that Google Earth really sucks when to comes to accurately depicting how things are on the ground. I am more convinced than ever that GE needs competition in the form of higher resolution aerial coverage. What they have now for the national forests is a joke, especially considering the level of technology currently available.
  • I got my new X8  platform delivered yesterday, and can't wait to start adding goodies.
  • After doing some research, I would like to use the X8 fling wing for a platform. There are of course other platforms, but its high payload and large wing span should help alleviate some of the challenges associated with high elevation flying. If anyone knows of reasons why this would not be a good idea, I am always open to hear them.
  • Depending on how low you want to go, light planes flying slowly will have a harder time to generate steady images while compensating for winds, mainly when flying inside moutain turbulance wake.
  • http://www.stenulson.net/rcflight/index.htm
    Take a look at this site. This guys flies his RC planes at 13,000 all the time. I think it is just a matter of customizing a plane appropriately.
    RC AIRCRAFT DESIGNING, BUILDING, & FLYING
    How hot will it be at your 13,000' obviously not too hot but the density altitude will be impressive if say it plus 10.
    I quite easily have a DA of 8000' here in the summer and I live at 5000' I have a 1.2m wing that can carry my 100gm Canon IXUS camera fairly easily but I would not want to go much higher. A lightly build X8 ought to do the job but that won't fit in a backpack.
    The machine will be flying pretty quick at those altitudes so you will need a big space and a deal of skill to operate it. Keep the AUW down, you might even consider building a balsa wing which will be way more fragile to keep the weight down.
    I'm going to say it again so you get it. Keep the weight down. Anything over 2kg in weight will be very hard to chuck at 13,000' You will probably need an assistant to do that as I can forsee it getting away at some un predictable angles.
    Oh if there is a slope to launch from chuck it from that, it will give you height straight away.
    Staying close to the ground will give you very little overlap have a look at KB's book Secrets of Photomapping  and make a sea level smaller craft to learn to fly on and experiment with mapping, its easy but you have to think a little.
    If you want FLIR and professional sensors you will be spending way more than a Sensefly costs. The biggest problem I can see is charging batteries, if its cold at your location you can count on the flight time being halved from sea level. You will need pockets full of SD cards as well along with a laptop to check the images were crisp.
    For all the effort, making a sensor pod and hanging it out of a Cessna might be easier. You can lift all you need and then head home for post production. We aim on 2 days post to one days shooting BTW and sometimes that's too little.
  • Matt, I would recommend any camera supported by CHDK for this kind of hacked mapping. The SX230 HS is great for automatically georeferencing your images. The E382 is designed for this kind of work but to be perfectly honest I'm not sure how well it would perform at such high altitudes!
  • Well, I found out I will need to find a platform with a greater wing area to accomodate that high of an operational altitude. But I also have to make it backpackable into very remote areas that are at least 10 miles from the nearest road. I also want it to have both a visual spectrum camera and a FLIR onboard to help detect ground temperature variation. But FLIR modules are very expensive, so will start off with just a regular digital camera.
