0 Using APM2.5 Power module with APM2.0 Posted by entropia666 on September 27, 2013 at 11:52am Hi all,I would like to use the APM2.5 Power module with APM2.0, is it possible?I don't need to power the APM actually, just the voltage/current readings...Thank you very much,Michele You need to be a member of diydrones to add comments! Join diydrones Email me when people reply – Follow
Hi Michele
Yes, this is possible. Have a look at this thread: http://www.diydrones.com/forum/topics/2-0-board-and-the-apm-power-m...
The easiest way is probably to solder three wires to the GND, V and A pads on the power module and connect them like you would connect the AttoPilot sensor (See: http://code.google.com/p/arducopter/wiki/AC2_Current).
Be aware that you need to set VOLT_DIVIDER to 10.1 to get the correct readings from you battery (See: http://copter.ardupilot.com/wiki/arducopter-parameters/#Voltage_Div...)
Daniel
