Using felt on Baro
Hi Jason
I have soldered my filter pads .....  but wondered if I also need to add a felt pad to the baro as I have the IMU inside a plastic case mounted on the top of my Hexa..  It isn't sealed as a small part of the base is cut away for the wires to exit.
Also a couple of comments on the 2.0.24A was asking if it was OK to use with a hexa.  Can I use 2.0.24b with my hexa.
Thank you for all the great work.  Only a small thing (although really important to me) I got camera stabilization working last night with 2.0.23 and my gopro is spot on when moving the hexa in both axis.  Never managed that in Ardupirates as the camera would always overshoot on its movements.
I'll try and load the latest stuff later today.  Thank you again for all your efforts.  I benefit from your and others obsession.  Don't get over it :)
Philip
  • nobody can answer for sure: test it
    if it has to much noise, add felt
