Using Flying wings for aerial mapping
Hello forum,
First of all some background...
Having spent a good 2 years playing about with an Skywalker, Ursus and a Canon camera running  CHDK, and designing my own uav, which actually flew recently ,I have come to the conclusion that flying wings may just be the best type of platform for short range aerial mapping tasks to create DEM, DSM models for GIS purposes.
The Skywalker was okay (but quite fragile, and now in pieces!), but I think it is too small to fit a roll gimbal on it. And I've found that if pictures are taken on a slight angle, it is very difficult to use software to tile them up nicely. this is my best effort, but far from perfect. The roads on the right do not line up as the camera must have been on a 45 degree angle when the picture was taken. (click for larger resolution) - It was taken using an ixus80 attached to an URSUS Airframe
3690979741?profile=original
Realizing that I need to use an airframe that can accommodate a stabilized roll gimbal, i started to design and build my own twin boom design. It took 6 months from initial design, to first test flight. It has a wingspan of 2.4m - AUW of 5kg, and a flight duration of around 30 minutes with 2 x 5000mah packs. However it needs a heck of a lot of room to take off and land, something i don't have in the areas i need to take photos.
Picture of twin boom plane...
3690979788?profile=original
What are peoples experiences with using flying wings for this reason? I have the following types of flying wings, and wondering which one is the best to begin with?
  • jp-si 48" span Zagi
  • Scaled up 60" span jp-si Zagi (hot wire cut by myself)
  • x8 2m wing
I have been using the 60" wing to test the APM2 and 3dr radios. And was using the URSUS (now in pieces after a nasty crash!) as a test platform to practice with the Canon CHDK Kit.
Here's a few pictures of the wing and camera....(click images for larger version.)
3690979799?profile=original3690979812?profile=original
My question is how straight forward do you think it is to fit a roll stabilized gimbal to any of the above airframes?
  • RoboFlight RF-70 70" EPP 2.0 Kit Promotional Offer - $850 US Dollars
    ***Please email phil@agpixel.com if interested
    3702106494?profile=original
    3702106168?profile=original
    $850 US Dollars
    Please message me for more details if interested. This can be launched via bungee cable and hook even with full payload. EPP 2.0 is much more durable than traditional UAV foam options.
    Highlight Video: https://vimeo.com/107972900
    RF-70 Flying Wing: Performance – Specifications
    SPEED:
    Maximum at Sea Level 55 knots
    Cruise 35 knots
    RATE OF CLIMB 800 feet per minute
    SERVICE CEILING 10,000 feet MSL / 400 feet AGL
    STALL SPEED 10 knots
    MAXIMUM WEIGHT 13 pounds
    STANDARD EMPTY WEIGHT 6.5 pounds
    MAXIMUM USEFUL LOAD 6.5 pounds
    WING LOADING 2.14 ounces/ft²
    BATTERY CAPACITY 10,000 mAh
    BATTERY VOLTAGE 14.8 volts / 4S
    RECOMMENDED MOTOR Hyperion ZS 3025 8-Turn 970 KV brushless outrunner
    PROPELLER 12” X 8”
    DESCRIPTIVE DATA:
    AIRFRAME
    2.0 Density Expanded Polypropylene (EPP 2.0 Density) foam
    Designed and Manufactured in the US
    PAYLOAD COMPARTMENT DIMENSIONS
    Front Bay: L 13” x W 5” x H 3”
    Rear Bay: L 12.5” x W 5” x H 3.5”
    Side Bays: L 7” x W 3.75” x H 1.5”
    RECOMMENDED AUTO PILOT
    3D Robotics PixHawk
    Designed and manufactured in the US
    RECOMMENDED ENGINE
    Number of engines: 1
    Engine Manufacturer: Hyperion
    Engine Model Number: ZS3025B-08
    Engine Type: Electric Brushless Outrunner
    RECOMMENDED ELECTRONIC SPEED CONTROL
    Manufacturer: Castle Creations
    Max Continuous Current: 75 Amps
    RECOMMENDED PROPELLER
    Manufacturer: Advanced Precision Composites
    Propeller Model Number: APC12080E
    Number of Blades: 2
    Propeller Diameter: 12 inches
    Propeller Type: Fixed Pitch
    Propeller Material: Molded Nylon
    RECOMMENDED BATTERY
    Battery Type: Lithium Polymer
    Battery Capacity: 10,000 mAh
    Battery Voltage: 14.8 volts
    Battery Cells: 4 cells in series
    STANDARD WEIGHTS
    Maximum Weight: 13 pounds
    Empty Weight: 6.5 pounds
  • 3702106082?profile=original
     construction site
    • How do you use the black and white squares?
      • These markers are used as Ground Control Points. During postprocessing they help to keep scale and transform precisley between coordinate systems (primary/secondary). All measurments on the construction site must be calculated with the same reference system (XY and H). I.e. after flight you get photos geotagged with accuracy of 2-15m in WGS 84 (X,Y,Z from ellipsoid). You want to obtain 3D model in polish planar coordinate system called "2000"  and height reference system "Kronsztadt '86". So , we use GPS+RTK (kinematic) or static receiver to measure GCPs in with sub centimeter accuracy.
        • Thank you for the explanation, i appreciate it.
          • 3702852134?profile=original3702852285?profile=original
            @LL in one - 3layers case. A pocket for markers (GCPs) will be added soon.
  • Hi All ,
    this is my mapping wing, 97cm wingspan, 850g takeoff-weight (including 200g 12MP camera), 3S 2200mAh, flight duration at 11m/s up to 70mins, flight with 15m/s 30mins. No airspeed needed. UV filter. Chinese APM2.6+GPS+MAGNETOMETER+433Mhz telemetry onboard. Wind conditions: 12m/s constant wind (blows up to 15-16m/s). Real carbon cover mats.
    3691248098?profile=original
    3691248204?profile=original
    and 2nd version - 1m wingspan, 1450g ready to take off including Sony Rx 100 (20MP), 30-45mins flight, LiPo 3s 4600mAh , bungee or hand launching, 3DR Pixhawk or APM onboard. UV filter. Real carbon cover mats.
    3691248273?profile=original
    start:
    https://www.youtube.com/watch?v=UWnTD7lSL_k
    Follow the customer wing (low quality, sorry)
    https://www.youtube.com/watch?v=GmVdk6CYVOc
    3691248155?profile=original
    Cheers,
    Rafal
    • Rafal, any chance you can share any details or build info on the wings themselves? Really nice work
      • Thanks Justin, Marcin and Chad.
        I am sorry but I can not tell more details. I hope it will be available on the market soon. Typical FPV version is taken into account as well.
        Few wings are sold and work on the building site (orthophoto, volume calculations, as built documentation) in small and big companies. I see a space on the market for my DIY projects based on APm/PixHawk - low price and excellent results.  The problem is hot wire cutting. So far I used to cut by "hands" and it took all day for one set. Now I am thiniking about purchasing hot wire plotter to start production.
        A friend of mine has also adopted camera for NIR and confirmed results.
        BTW, one of my project made for customer:
        https://www.youtube.com/watch?v=_6Sr67hGomY
        I do full composite bodies as well.
        Rafal
    • I like it :-)
      Made in Poland.
DIY Robocars via Twitter
Sunday
Saturday
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
