What can be the problem?
This is a Skywalker with APM, uBlox GPS and airspeed sensor.
PID parameters are loaded from Skywalker.param file which downloaded from APM Wiki.
What can be wrong?
Please help.
Hakan Karakurt
  • I removed airspeed sensor and re-calibrated radio after loading skywalker.param file.
    It flew GREAT!
    Everything was superb.
    Now, what should I do to deploy airspeed sensor correctly?
    Thank you so much.
    Try without the airspeed sensor. You may have it hooked up wrong.
    Also, did you go through the full setup process and ground test procedure?
