What kind of amps are people drawing?
Right, I'm not entirely sure my set-up is perfect but I'm working on it...
I'm flying a H-800 (Hobbyking H-800 Hex frame)
On this I have the following parts....
DYS D4215 - 650kv motors from RCTimer,
RCTimer 45A ESC's,
Tarot Retractable Landing Gear,
Tarot mounting parts to mount the battery plate and Gimbal,
A cheap eBay 2 Axis Gimbal,
Pixhawk FC,
FRSky X8R reciever,
3DR Radio,
MAVLink board and OSD.
And a 4S, 6200mAh Zippy Compact battery....
Now, I'm getting 6-7 minutes comfortable flying time....
I have recently upgraded to Mission Planner 1.3.36 .37 Doesn't work for me?) and loaded Firmware version 3.3.3 so I needed to re-cal' my accels and compasses....
after that I hooked up my amp meter and throttled up to the point it wanted to lift but not quite...
My amps were up at 28ish.... Would that sound about right for a copter with an all-up weight of about 4.3Kg?
  • Calc shows that you need 36 amps to hover. And your throttle is near 60% at hover.
    My 800 quad with 3-axis gimbal needs 20 amps for hover. But it has quite efficient setup.
    I would tell that it sounds right for me.
    You can connect second 4S 6200mah in parallel. As i see in calculations that you will get 9-10 mins with two batteries.
    • Thanks for the reply Vital Belikov...
      I really must have a look at my telemetry screen to see what Amps I'm taking in the air...
      On the stick, it's only just over half way...
      I need to find a way to make it more efficient... I am actually building a bigger battery plate so the second pack is going on... :-)
      • No problem :)
        To be more efficient you need to find ballance between low kw motors, big props, light weight and big battery :)
        • Ha! That simple! Lol... ;-)
  • Ah... I knew I forgot something...
    Prop's are RCTimer 13X5.5 Carbon....
    The batteries are very new at about 5 full flights plus using them at set-ups....
DIY Robocars via Twitter
RT @chr1sa: The next @DIYRobocars virtual AI race is tomorrow morn at 9:00am PT. You can watch live on Twitch https://www.meetup.com/DIYRobocars/events/275268196/
13 hours ago
New version of Intel OpenBot! This resolves many of the issues with the first version, including a much smoother tr… https://twitter.com/i/web/status/1352395636369313798
yesterday
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
Tuesday
Monday
Monday
Jan 15
Jan 15
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
David Hori liked Isabella Domi's profile
Jan 12
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Jan 11
Jan 6
Dec 28, 2020
