“The reason that we switched from the helicopter to the fixed-wing vehicle is that the fixed-wing vehicle is a more complicated and interesting problem, but also that it has a much longer flight time,” says Nick Roy, an associate professor of aeronautics and astronautics and head of the Robust Robotics Group. “The helicopter is working very hard just to keep itself in the air, and we wanted to be able to fly longer distances for longer periods of time.”
Autonomous robotic plane flies indoors
New algorithms allow an autonomous robotic plane to dodge obstacles in a subterranean parking garage, without the use of GPS.
re: Lidar Lite, non-laser Lidar Lite, LED-based Lidar Lite
What is featured on a number of promotional pictures by Lidar Lite group looks like
non-laser UV LED/IR Led Lidar Lite
but what is offered for sale is laser-only Lidar Lite version.
Since developing Lidar Lite is like developing GPS receiver on your own ( really complicated thing) I plan to buy laser-based Lidar Lite and replace laser to UV/IR Led for tests (UV Led transmitter/receiver pair or IR Led transmitter/ receiver pair is available.
At the same time I am developing Led-pointer to replace laser-pointer, to some extend to experiment with lens, cooling, collimator and to test range for the given wattage.
If LED pointer is ready (UV or IR + visible light beam in parallel) I can order Lidar Lite for tests, described above.
For IR tests I use single lens night vision system at $200
For UV tests I plan to use spectroscope and image data processing to extract UV bandwidth.
For indoor tests I plan to build Led-based 3D scanner (for use with 3D printer)
$200 night vision system is highly sensitive and can detect blinking IR Led from 100 m.
Developing collimator, lens to concentrate UV/IR beam to receive reflected UV/IR
beam from objects distant as close as 10, 20, 30, 40 m
can give me an answer on the feasibility of such approach.
@Laser Developer
@LidarLiteGroup
are the leaders , so I would like to know their opinion about my approach.
You see why I'm confused?! Their FAQs discuss a product that doesn't exist (a non-laser LED Lidar-Light).
Any links they provide, however, lead to a product which clearly states it is laser-based.
That was my original point. Talk of a non-laser Lidar-lite, but no follow-through.
My reason for entering this thread was to warn people to read the fine print of their country's regulations before they build a business plan around UAV-with-onboard-lasers. In other words, it's not just a technical issue. It may be a legal one (it is in Canada).
The company mentions 'eye-safe, laser hazard-free'. But their website is so confusing, it's not clear if they're still referring to a non-laser or a laser product.
But even if they mean the laser one - it doesn't matter (in Canada) whether they think their product is eye-safe. It only matters that Transport Canada strictly regulates all onboard lasers - 'no exceptions'.
People might be unpleasantly surprised if they're not careful.
I still have not seen any link to a purchasable, non-laser Lidar-Lite equivalent. If the authorities don't change their opposition to onboard lasers, there may be a (large) market for the non-laser equivalent, even if it performs less well (as I assume it must).
But if the authorities change their minds tomorrow, no one will want the non-laser version.
(during Transport Canada's recent request for public feedback on proposals for the comprehensive new UAV regulations they will reveal next year, I made the point that blocking Lidar is going to lead to more collisions and injuries, not fewer. I even sent them a link to this company's 'eye-safe' product).
I also have no idea how other countries' regulations treat on-board lasers.
George
Darius Jack > George KellyNovember 27, 2015 at 4:23am
Dear George,
You are exactly right that non-laser lite Lidar is marketed, described but not offered as a market product.
Yesterday I have tested $200 night vision device coming with camera i recorder, offered in a market.
Pulsed IR light generated by pressing a button in TV remote has been detected by IR sensor matrix could be watched on LCD screen.
Today I plan to test power Led equipped with collimator and lens from DVD laser recorder
Led diode is not going to "lase" but hope to build basic LED pointer for tests.
Pls let me know your opinion.
In the simplest form of laser diode, an optical waveguide is made on that crystal's surface, such that the light is confined to a relatively narrow line. The two ends of the crystal are cleaved to form perfectly smooth, parallel edges, forming a Fabry–Pérot resonator. Photons emitted into a mode of the waveguide will travel along the waveguide and be reflected several times from each end face before they exit. As a light wave passes through the cavity, it is amplified by stimulated emission, but light is also lost due to absorption and by incomplete reflection from the end facets. Finally, if there is more amplification than loss, the diode begins to "lase"."
It's very difficult currently to get approval for any onboard lasers - even the weakest ones - in Canada. Don't know about other places (but countries seem to be following each other's lead these days in drafting their regulations).
To put LIDAR-light on a commercial drone requires a full permit application (minimum 20 working days, but has recently taken as long as several months), followed by a special review by Health Canada (minimum 30 days).
And until you have a considerable track record, that applies to each single intended use!
"Before a certificate applicant can operate a UAV fitted with laser equipment, the applicant has to complete a 'Notice of Proposal to Conduct Outdoor Laser Operations...
An aeronautical assessment is then conducted and the documentation is forwarded to Health Canada...The normal process time is at least 30 days to review the notification and determine if a laser authorization can be issued.
There are no exceptions to the requirement for this process. For example, even if the aircraft is going to be fitted with a short-range laser rangefinder to act as an altimeter, the equipment on the aircraft could cause a hazard to aviation safety - therefore, an assessment is required."
[Transport Canada]
The result, no doubt, of a@@holes shining laser pointers at airliners.
You can use a precise (+-2cm) Indoor "GPS": http://marvelmind.com/.
Here a couple of demos:
finally got full text, web link to the robotic plane from the above video
http://news.mit.edu/2012/autonomous-robotic-plane-flies-indoors-0810
Hi bd,
what "hyperspec" do you mean ?
Pls refer me to the original message.
If you know any market potential pls let me know.
@Laser Developer
@LidarLiteGroup
darius
manta103g@gmail.com
Thank you Jacob,
excellent video.
I would like to build alike indoor navigation system.
Hi Darius,
Yes, I've been to their site.
George
Dear George,
And don't underestimate the regulatory issue.
George
What the problem with Lidar George? I just buy one glup!
[Transport Canada]
George
1
2
3
of 3 Next
