I posted the following in perhaps the wrong category...
http://diydrones.com/forum/topics/xbee-2-4ghz-telemetry-to-spektrum-dx8
In a nutshell, I'm trying to have telemetry data - battery voltage sent to my Spektrum DX8 instead of a laptop. Possible? Other options?
Thanks,
Jason
It takes a bit of work, but look over these for similar work/examples -
http://diydrones.com/profiles/blogs/dx6i-interception-board-rfm22
http://diydrones.com/profiles/blogs/spektrum-dx6i
http://diydrones.com/forum/topics/telemetry-openlrs-and-apm
http://diydrones.com/profiles/blogs/openlrs-firmware1-10-with-trans...
There are others, one I wanted to give you that is most like what you are asking, but I could not locate it. A blog from another member who snooped on the mavlink with an arduino mini pro and slipped only the battery data over a similar TX/RX telemetry link, then displayed on the TX. Perhaps you can locate it where I have failed. Then you will have, not three projects as instruction, but rather three authors who have walked in your shoes before you with the same goal, but with different gear.
