XBee Pro 900 XSC Wire Configuration
Hello i´m trying to configure this 2 modules of  900mhz xbee with this XCTU 32-bit ver. 5.2.7.5  but so far and even after try to read all the help available on the internet, it just dont comunicate one to another. So this is the problem i have :
1- I have conected both modules in the computer and they read the info for each bord;
2- One of them is on COM3 and the other on COM4;
3- Now in the tab "Modem Configuration" Set one modem as a Coordinator and the other as an End Device but i couldnt find that option;
4- "Set PAN ID to any unique number used between the two modems" but i just dont find that option also!
5- Use the Serial Number of each device as the Destination of one another. (Both High and Low addresses). As you can see in the pictures i have only one "Destination adress"...... and not both HIGH and LOW  as i should.
So i will apreciat any help for this problems!!!
  • Hi guys
    I have the same problem with xbee xsc(i cant write anything to apm).Can you guys please tell me what settings do you have under Xctu/modem configuration/Serial interfacing options/FL-software flow control and Xctu/modem configuration/Networking/TT-streaming limit?.
    When i connect apm telemetry port straight to ftdi i can read/write but with xbee it seems to be only one way communication.
    Also in streaming limit settings by default is FFFF(dec 6535?) witch i think it means only after 6535 bytes or a pause the xbee on the plane side can receive commands?
    Thank you and please excuse my english.
  • 3692349716?profile=original
  • 3692349873?profile=original
  • 3692349777?profile=original
  • 3690912272?profile=original
  • 3692350012?profile=original
David Hori liked Isabella Domi's profile
Jan 12
