250 FPV Racer using Mini APM
3689678404?profile=originalHi All, here is my 250 FPV Racer I designed and 3D printed. It uses a mini APM as the flight controller and also has a GPS and telemetry for missions. The arms are 15mm carbon tubes with SN20A esc's in the arms. The files can be downloaded here http://www.thingiverse.com/thing:1256900
3689678422?profile=original
3689678447?profile=original
3689678464?profile=original
Telemetry/OSD board at the top, Mini APM in the middle and PDB at the bottom.
3689678479?profile=original
688g AUW with 4S 2200mah battery
3689678370?profile=original
483g with GoPro and no battery.
3689678522?profile=original
367g without battery and GoPro
BOM:
Flight Controller
http://www.hobbyking.com/hobbyking/store/__74644__Micro_HKPilot_Mega_Micro_Sized_Flight_Controller_and_Autopilot_with_Leads_2_7_2_APM_.html
PDB
http://www.hobbyking.com/hobbyking/store/__74645__Micro_HKPilot_Mega_PDB_BEC_and_Volt_AMP_Sensor_30_5mm_Mounting.html
Telemetry
http://www.hobbyking.com/hobbyking/store/__74651__Micro_HKPilot_Telemetry_Radio_Module_with_On_Screen_Display_OSD_unit_915MHz_.html
XT60
http://www.hobbyking.com/hobbyking/store/__49828__Black_XT60_Male_5pc_.html
Battery Buzzer
http://www.banggood.com/Wholesale-1S-8S-Li-po-Battery-Voltage-Tester-Checker-Indicator-Monitor-Buzzer-Alarm-p-26049.html
5.8Ghz Transmitter
http://www.banggood.com/Eachine-ET600-5_8G-32CH-600mW-Super-Light-Transmitter-p-974640.html
ESC's
http://www.banggood.com/DYS-SN20A-Mini-20A-SimonK-ESC-OPTO-2-4S-20-500Hz-for-Multicopters-p-974637.html
Motors
http://www.banggood.com/Sunnysky-X2204-2300KV-Brushless-Motor-CW-CCW-For-RC-Model-p-952075.html
Props
http://www.banggood.com/Gemfan-5x3-5030-Carbon-Fiber-Multirotor-Self-Lock-Propellers-CWCCW-p-972016.html
    Brilliant. How does it fly?
  • Nice job! I like the use of carbon tubes and the carbon fiber props.
  • 100KM
    Stunning - I think there's a huge commercial market for these tiny apm quads - you can have one ready in the boot and pop them up for inspection, security (neighborhood watch), journalism, etc. Well done.
  • What 3D printer did you use and the material?
  • That is absolutely a neat set up, any flight videos you may have please send.
  • very nice design
  • I really like it!! Much better to have the FC and all other electronics in a protective box! What sort of flight times do you get?
  • I'm really starting to enjoy these 3D printed 250/210/180 frames which house all the components too.
  • cool
  • That is outstanding. How does it fly? BTW - if those Sunnyskys are from Bangood 99% certainty they are fakes. Keep an eye on your bearings. The fake ones can be decent enough when you replace the bearings.
