To make center of gravity (COG) 's tuning easier when attaching your battery on its ship, here is a quick and simple 3D printed sliding battery mount system.
Bottom plate is fixed to your plane (copter), battery is placed on the sliding tray. Sliding tray is moved right or left until COG is placed where you want it to be. Then everything is locked in place with velcro straps:
You wanna slide ? hereunder STL and Autodesk123D files,
- portebatterieTalon.123dx
- portebatterie.stl
- Dimensions of sliding tray :58mm x 150mm
- Dimensions all-in : 70mm x 150 mm x 15 mm (height)
- bottomtray.stl
- uppertray.stl
Enjoy,
Hugues
AirbotServices
Here are the separate trays, see end of post.
I'm using makerbot desktop software. there is only bottom plate on makerbot desktop. Please separate it.
Hi Alp, the STL files contains both plates. Do you need separate files ? If yes i can split it for you.
@Hugues,
Thank yor for bottom plate's STL file. What about tray's STL file? :)
Thanks for the STL this is just what I was looking for
cheers
