3689686073?profile=originalWe make new modem for diy use. Can be use as a transparent UART modem. Board have also USB to UART converter.
433MHz (414-454MHz) 100mW (20dBm) Super Long Distance LoRa Wireless data modem with USB and UART interface.
General:
LoRa LRS series is a low cost, high performance transparent transceiver with operating at 433MHz. It is LoRa/FSK/ GFSK/OOK modulation variety. It features small size, high output power, high sensitivity, long transmission distance and most of the parameters can be set via the command. Receive and send data to automatically switch. U s e generic UART interface. It is easy to realize the wireless data transmission with only providing the UART data. It is flexible for the users to set the UART baud rate, output power, data rate, frequency select, modulation mode select etc parameters. It is your ideal choice for designing wireless data transmission products which can be widely used on wireless data transmission field.
Features:
  • Low cost, high performance , high reliability
  • LoRa/FSK/GFSK/OOK modulation, 2-way half –duplex communication, strong anti-interfere
  • Frequency Hopping Spread Spectrum
  • 414-454MHz ISM band,globally license free.
  • Maximal output power100mW(20dBm),output power adjustable between 2-20dBm
  • LORA Sensitivity -139dBm
  • Supply current for Tx 130mA@20dBm, 35mA@13dBm
  • Supply current for Rx 16mA
  • Low current sleep mode 2uA
  • Standard UART interface and USB interface
  • Operation frequency can be configured, acceptable for several modules working in different frequency with no disturbance on each other.
  • RF parameters as needed, users can be modulated by software
  • Easily use, auto exchange on communication & transceiver
  • Communication speed 1.2kbps -115.2kbps,can be modulated through software
  • Afford Sleep control signal,user self control work duty cycle
  • With LED indication
  • Longer transmission distance,over 5Km in open air
  • Small size 42x30mm, USB connector and 4 pin connector for UART
  • Weight 8 gramm
  • SMA antenna connector
  • Tuning free
  • Accord FCC,ETSI standard
3689685971?profile=original
  • Does this use the same firmware as the 3DR radios? And again, is it required to buy two for one copter?
  • 915MHz version avail now!
  • Where is the 915MHz version, and do I need two?
  • T3
    Hi CSG, hi all,
    Interesting product!
    Can someone provide some info on ETSI/CE compliance and restrictions?
    It seems that in Europe only the 868 MHz version is ETSI compliant. If I understand correctly, there is either a restricted duty cycle or Adaptive Frequency Agility (AFA) and Listen Before Talk (LBT).
    For UAV telemetry operating with 1 or 10% duty cycle is not reasonable. So AFA+LBT is required.
    @CSG what is implemented in your 868 MHz modules - Duty cycle or LBT + AFA?
    Another thing regarding 433/868 MHz. As far as I know the common 433 SiK modules are not allowed because the user can change the power by himself via the firmware. Does this apply to the 868 MHz as well?
    Thanks and best regards,
    Thorsten
  • I think it shouldn't be a problem inside EU - that's where CSG is located.
  • We can make also AES encryption but can be problem with shipping.
  • One thing I don't understand is that why so few radios have encryption. It's not hard to do, but it's an important feature for anyone doing commercial work with UAVs.
  • I've made it 73km with a simple dipole antenna attached to RF1276 (SX1276), and would have gone more, if I were higher, as I've reached a horizon limit. -148dB RX sensitivity. Not willing to promote anything, but 168dB link margin is quite something, especially when TX/RX pair costs $45. I'd say its a best LoRa stuff in a market today.
    Truth, going at such a low bitrates requires modified telemetry protocols, messages as short as possible, sentences rotated. Native APM telemetry won't work.
  • @Guy McCaldin, do you have any experience with the Microhard radios?
    $79 for an encrypted 2W radio is a pretty fair price I think.
  • Is this a point-to-multipoint solution?
