Here are some Photos showing how to get 6 positions on a Futaba 9C super
It will set them for these 2 switches
go to advanced settings choose PMX-6 CRV
first page 1/2 of PMX-6 CRV should be set as shown below
Second page 2/2 of PMX-6 CRV should be set like this (below)
Make sure to note the order in the planner when setting up your flight modes, the switching order is not 1-6 in order.
that should do it,
I follow what you said, but it looks like only positions 1, 3, and 6 are effected. When I move both switches, the other locations are not highlighted.
Update: With the above settings I had endpoints setup on CH5/GEAR of 80%/80%. With CH5/GEAR endpoints at 100%/100%, here are my settings:
AUX-CH CH5=>Sw-C
Mix PMX-6 CRV
MAS=>5, SLV=>5, LINK=>ON, SW=>D, POSI=>DOWN
POS 1=>-71%, (2=>-40%), 3=>-17%, (4=>+10%), 5=>+59%
(position 2 and 4 have no effect)
One thing not mentioned is you need to have channel 5 configured to switch 'C'. Using the curve mix is definitely a good idea; here's what I ended up with:
AUX-CH CH5=>Sw-C
Mix PMX-6 CRV
POS 1=>-63%, (2=>-40%), 3=>-22%, (4=>+10%), 5=>+49%
Ok got it!! Thanks, i will try it.
Switch C has 3 positions X 2 positions of switch D gives you a total of 6 combinations.
So with this setup you only have programed switch D .....how you switch true all the 6 positions with it???
thank you very much.
