6 positions for Futaba 9C Super
Here are some Photos showing how to get 6 positions on a Futaba 9C super
It will set them for these 2 switches
3689494514?profile=original
go to advanced settings choose PMX-6 CRV
3689494440?profile=original
first page 1/2 of PMX-6 CRV  should be set as shown below
3689494537?profile=original
Second page 2/2 of PMX-6 CRV should be set like this (below)
3689494478?profile=originalMake sure to note the order in the planner when setting up your flight modes, the switching order is not 1-6 in order.
that should do it,
  • I follow what you said, but it looks like only positions 1, 3, and 6 are effected.  When I move both switches, the other locations are not highlighted.
  • Update:  With the above settings I had endpoints setup on CH5/GEAR of 80%/80%.  With CH5/GEAR endpoints at 100%/100%, here are my settings:
      AUX-CH CH5=>Sw-C
      Mix PMX-6 CRV
        MAS=>5, SLV=>5, LINK=>ON, SW=>D, POSI=>DOWN
        POS 1=>-71%, (2=>-40%), 3=>-17%, (4=>+10%), 5=>+59%
          (position 2 and 4 have no effect)
  • One thing not mentioned is you need to have channel 5 configured to switch 'C'.  Using the curve mix is definitely a good idea; here's what I ended up with:
      AUX-CH CH5=>Sw-C
      Mix PMX-6 CRV
        POS 1=>-63%, (2=>-40%), 3=>-22%, (4=>+10%), 5=>+49%
  • Ok got it!! Thanks, i will try it.
  • Switch C has 3 positions X 2 positions of switch D gives you a total of 6 combinations.
  • So with this setup you only have programed switch D .....how you switch true all the 6 positions with it???
  • thank you very much.
