I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
did you edit it with notepad as i mentioned?
After my edit, i tried the files with autocad 2000 to 2010 as well as volo view 3 and dwg trueview 2011 and all dxf files are viewable. please make sure you have downloaded the raw files."note: it doesn't have numbers as prefix... i only added the numbers for much better illustration." if you still can't do it, please send me your email and i'll forward my files.
Thank You
to open the dxf files uploaded by Jani using autocad or any viewer, just edit the dxf files using notepad. delete lines 26 to 49 shown below:
26 ENDSEC
27 0
28 SECTION
29 2
30 TABLES
31 0
32 TABLE
33 2
34 LAYER
35 70
36 1
37 0
38 LAYER
39 2
40 Default Layer
41 70
42 0
43 62
44 1
45 6
46 CONTINUOUS
47 0
48 ENDTAB
49 0
Jani, I'm using Corel to import and prepare the files you sent me without any problem. It's the first time I see that error occurring.
Thanks for corel info, I try to figure it soonest and then upload all files to repository again. What program did you use last time?? You did norlt have any problems earlier did you?? Due those are same files you haveeb using for modelking..
When I receive mine... I can imagine the advertising scene: the volumetric light spreading out by openings on the box with a intense glow inside it... The child face illuminated... hahaha
I'm currently on mobile away from computers so cannot test in corel. Adobe illustrator, turboCAD, google sketchup they all import those ok.
Randy, you know best for the best people ;)
Wow, I knew you were working on this but had no idea it would look so professional. Really great.
-Randy
I try to get them all done during beginning of next week. Tho I wonder what you could you have on PDF document? Unless you print it our to paper and then mark by pen to your plywood or some...
48
49
50
51
52
of 82 Next
