The ardupilot development team is proud to announce the release of version 3.1.0 of APM:Plane. This is a major release with a lot of new features and bug fixes.
The biggest change in this release is the addition of automatic terrain following. Terrain following allows the autopilot to guide the aircraft over varying terrain at a constant height above the ground using an on-board terrain database. Uses include safer RTL, more accurate and easier photo mapping and much easier mission planning in hilly areas.
There have also been a lot of updates to auto takeoff, especially for tail dragger aircraft. It is now much easier to get the steering right for a tail dragger on takeoff.
Another big change is the support of Linux based autopilots, starting with the PXF cape for the BeagleBoneBlack and the Erle robotics autopilot.
Full list of changes in this release
- added terrain following support. See http://plane.ardupilot.com/wiki/common- ... following/
- added support for higher baudrates on telemetry ports, to make it easier to use high rate telemetry to companion boards. Rates of up to 1.5MBit are now supported to companion boards.
- added new takeoff code, including new parameters TKOFF_TDRAG_ELEV, TKOFF_TDRAG_SPD1, TKOFF_ROTATE_SPD, TKOFF_THR_SLEW and TKOFF_THR_MAX. This gives fine grained control of auto takeoff for tail dragger aircraft.
- overhauled glide slope code to fix glide slope handling in many situations. This makes transitions between different altitudes much smoother.
- prevent early waypoint completion for straight ahead waypoints. This makes for more accurate servo release at specific locations, for applications such as dropping water bottles.
- added MAV_CMD_DO_INVERTED_FLIGHT command in missions, to change from normal to inverted flight in AUTO (thanks to Philip Rowse for testing of this feature).
- new Rangefinder code with support for a wider range of rangefinder types including a range of Lidars (thanks to Allyson Kreft)
- added support for FrSky telemetry via SERIAL2_PROTOCOL parameter (thanks to Matthias Badaire)
added new STAB_PITCH_DOWN parameter to improve low throttle behaviour in FBWA mode, making a stall less likely in FBWA mode (thanks to Jack Pittar for the idea). - added GLIDE_SLOPE_MIN parameter for better handling of small altitude deviations in AUTO. This makes for more accurate altitude tracking in AUTO.
- added support for Linux based autopilots, initially with the PXF BeagleBoneBlack cape and the Erle robotics board. Support for more boards is expected in future releases. Thanks to Victor, Sid and Anuj for their great work on the Linux port. See http://diydrones.com/profiles/blogs/fir ... t-on-linux for details.
- prevent cross-tracking on some waypoint types, such as when initially entering AUTO or when the user commands a change of target waypoint.
- fixed servo demo on startup (thanks to Klrill-ka)
- added AFS (Advanced Failsafe) support on 32 bit boards by default. See http://plane.ardupilot.com/wiki/advance ... iguration/
- added support for monitoring voltage of a 2nd battery via BATTERY2 MAVLink message
- added airspeed sensor support in HIL
- fixed HIL on APM2. HIL should now work again on all boards.
- added StorageManager library, which expands available FRAM storage on Pixhawk to 16 kByte. This allows for 724 waypoints, 50 rally points and 84 fence points on Pixhawk.
- improved steering on landing, so the plane is actively steered right through the landing.
- improved reporting of magnetometer and barometer errors to the GCS
- added FBWA_TDRAG_CHAN parameter, for easier FBWA takeoffs of tail draggers, and better testing of steering tuning for auto takeoff.
- fixed failsafe pass through with no RC input (thanks to Klrill-ka)
- fixed a bug in automatic flow control detection for serial ports in Pixhawk
- fixed use of FMU servo pins as digital inputs on Pixhawk
- imported latest updates for VRBrain boards (thanks to Emile Castelnuovo and Luca Micheletti)
- updates to the Piksi GPS support (thanks to Niels Joubert)
- improved gyro estimate in DCM (thanks to Jon Challinger)
- improved position projection in DCM in wind (thanks to Przemek Lekston)
- several updates to AP_NavEKF for more robust handling of errors (thanks to Paul Riseborough)
- improved simulation of rangefinders in SITL
- lots of small code cleanups thanks to Daniel Frenzel
- initial support for NavIO board from Mikhail Avkhimenia
- fixed logging of RCOU for up to 12 channels (thanks to Emile Castelnuovo)
- code cleanups from Silvia Nunezrivero
- improved parameter download speed on radio links with no flow control
Many thanks to everyone who contributed to this release, especially our beta testers Marco, Paul, Philip and Iam.
Happy flying!
@Mike, I'm hoping that Matthias might do a wiki page on the FrSky telemetry setup soon.
@Ivan, APM2.6 is still supported, although some features (such as terrain following) just can't work on a 2.6. Eventually we will have to drop the APM2 support completely, but for now it still flies well.
Great! Going to test it soon! Is there any sign for attention for apm2.6 owners :) ?
A great set of enhancements. Thanks.
Where would I go to see more information about the item "added support for FrSky telemetry via SERIAL2_PROTOCOL parameter" please?
Consistently impressive stuff.
Thanks Tridgell
Thanks Tridge. I am a big fan of integrating flight controllers with TX telemetry.
For the price a FC, you get all of the telemetry sensors for free, could not be happier to see this development.
@Mark, for now it's the older D series, but Matthias is working on S-port support and we expect that in a future release.
Thanks Tridge, another great version update. They just keep coming.
Is the Frsky Telemetry the older D series or the newer Smart Port?
Great work!!
Thx, will hurry to test this on my Xuav Talon...
