ArduCopter 3.2 ready for wider use
After months of testing, ArduCopter 3.2 (aka APM:Copter) is ready for widespread use and we invite all users to give it a try.  In order to manage the support load at first it will be available only through the Mission Planner and APM Planner2's Beta Firmwares link.  This link is visible from the regular "Install Firmware" page if you check the "Advanced View" on the Config/Tuning >> Planner page.  On APM Planner2 the "Advanced View" it is under the File menu.
In about two weeks we plan to replace AC3.1.5 with AC3.2 as the default version dispensed by the ground stations.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner.  Please select Help > Check for Updates
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped ssupport for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks the Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release.  Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYawThor's Zombie Run&FollowMePhanivyas's Test, Rob's TradHeli, Christian's Test1&Test2Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more.  If you want to get involved check-out our dev wiki.
  • One more situation for me while running 3.2 RC14, see this video showing a mission with spline waypoints
    https://www.youtube.com/watch?v=_Sq9nA0MVeQ
    Each time a waypoint is reached, the platform will twitch.  I thought maybe the mission have some bad spline waypoints sets so I created another after clearing the old, same thing.
    Anyone know what could be happening?  I also posted 2 issues on the ardupilot.com 3.2 forum about other problems but no replies.
    @John,
    Sonar is supported on the APM2.6 if you're using the multicopter software (i.e. quad, y6, etc.) but not if you're using a traditional helicopter.
  • Thanks MarkM
  • I can't connect in Mission Planner Terminal mode after installing 3.2 on my APM 2.6. Maybe this is not necessary anymore as I successfully ran Compass/Motor Calibration from MAVlink. Haven't tried Motor Test from MAVlink yet though.
    Thanks for all the wonderful work developers! much appreciated:)
    Command line interface / Terminal has been removed from 3.2 due to flash space restriction on APM
    Does this mean no Sonar for APM 2.6 as well? I assume that since Mission Planner no longer lets me select it.
    Fantastic version - with no tuning my quad flies great, love position hold.
  • Randy
    Is it then going back to "normal" when released? It's a good thing speeding it up a little, but a few words in a dialog box before calibrating would be enough.
    According to Craig, the compass calibration in the Beta mission planner has been sped up.  I have not personally checked that the final numbers it calculates in the very short period of time are accurate but I think that Craig and MichaelO think they are.
  • I just rolled back to AC3.1.5 and reinstalled MP the same way as over, and same thing happens. I think this is the way it sholud be. It seems like MP have some calibration data and just need to get the rest. I don't know.
  •  I've uninstalled MP, deleted all files in MP folder and reinstalled ver.1.3.10. Then i pushed the "Check for beta updates" button on the help screen and now the version is 1.3.11 1.1.5426.22786. If it's a beta version, i don't know as it doesn't say. Roll back? Anyone?3701871082?profile=original
