ArduCopter 3.2 ready for wider use
After months of testing, ArduCopter 3.2 (aka APM:Copter) is ready for widespread use and we invite all users to give it a try.  In order to manage the support load at first it will be available only through the Mission Planner and APM Planner2's Beta Firmwares link.  This link is visible from the regular "Install Firmware" page if you check the "Advanced View" on the Config/Tuning >> Planner page.  On APM Planner2 the "Advanced View" it is under the File menu.
In about two weeks we plan to replace AC3.1.5 with AC3.2 as the default version dispensed by the ground stations.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner.  Please select Help > Check for Updates
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped ssupport for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks the Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release.  Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYaw,  Thor's Zombie Run&FollowMe, Phanivyas's Test, Rob's TradHeli, Christian's Test1&Test2, Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more.  If you want to get involved check-out our dev wiki.
  • Randy
    Is it then going back to "normal" when released? It's a good thing speeding it up a little, but a few words in a dialog box before calibrating would be enough.
    According to Craig, the compass calibration in the Beta mission planner has been sped up.  I have not personally checked that the final numbers it calculates in the very short period of time are accurate but I think that Craig and MichaelO think they are.
  • I just rolled back to AC3.1.5 and reinstalled MP the same way as over, and same thing happens. I think this is the way it sholud be. It seems like MP have some calibration data and just need to get the rest. I don't know.
  •  I've uninstalled MP, deleted all files in MP folder and reinstalled ver.1.3.10. Then i pushed the "Check for beta updates" button on the help screen and now the version is 1.3.11 1.1.5426.22786. If it's a beta version, i don't know as it doesn't say. Roll back? Anyone?3701871082?profile=original
  • When re-calibrating the compass after installing AC3.2 it stops after about 20 seconds and the lady says "calibration complete" and i see the calibration dialogs # for the two compasses. I tried to upgrade to MP 1.3.11 and the same thing happens. Am i doing something wrong? I choose Pixhawk in Orientation before pressing Live Calibration.
  • Any ideas about why the Follow Me mode isn't controlling the camera Tilt?  it just remains straight ahead.  Would appreciate some link to the wiki or other source on how to configure it.
    thanks.
  •  Frank Blessmann
    I have the same problem with my Pixhawk, Loiter is Ok, but PosHold not work.
  • Chim, I haven't looked at the code to see exactly what is going on.  But I did set large circle radiuses, with a fast turn speed, and it did not go very fast.  So, either by chance or by choice, it seems to be speed limited.
    @lakeroe,
    I think this blog is a difficult place to do support.  Can you raise an item in the APM Forum?
    @Alex,
    Yes, I found out yesterday that the MissionPlanner is using the "ArduCopter-stable" tag in our git repository as the source of the parameter description.  this means that as soon as we replace AC3.1.5 with AC3.2 as the default version, the regular stable MissionPlanner will also pick up the correct parameter information including the PosHold flight mode.
