ArduCopter 3.2 (aka APM:Copter) has been released as the default version replacing AC3.1.5. This is the exact same version that we invited all users to test two weeks ago. Users who wish continue using AC3.1.5 can find it under the "Pick previous firmware" version on the MP's Install Firmware screen.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
- PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
- ACRO mode handling improvement EXPO (for faster rotations)
- Drift mode uses "throttle assist" (similar to AltHold)
- Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
- Spline waypoints
- Do_Jump, Conditional_Distance, Conditional_Delay fixed
- Do_Set_ROI persistent across waypoints
- Condition_Yaw accepts relative heading (i.e. current heading + 20)
- Reset horizontal position target when taking off in AUTO to avoid lean due to GPS position drift
- Rally points (Pixhawk only)
New Sensors/Devices:
- Lidar-Lite Range Finder, SF02, MaxBotix I2C sonar and Analog sonar (which was missing for Pixhawk)
- EPM Gripper
Safety Features:
- EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
- Baro glitch detection
- Pre-arm check for Gyro calibration success
- Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
- Parachute support (Pixhawk only)
- Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
- EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
- Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
- Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
- Pixhawk users will need to recalibrate their compasses
- PosHold won't show up as option on FlightMode screen if you have an old version of mission planner. Please select Help > Check for Updates.
- Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO.
- Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
- Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
- Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
- Dropped support for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks to Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release. Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYaw, Thor's Zombie Run&FollowMe, Phanivyas's Test, Rob's TradHeli, Christian's Test1&Test2, Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more. If you want to get involved check-out our dev wiki.
I will try RTL next flight. Hopefully it cab do safer landings
I don't use land mode on FS I use RTL and it works perfect. Maybe change it to RTL which makes more sense to me and see if it still drifts.
Btw, how do you calibrate the current sensor? I was only able to calibrate the voltage sensor.
Have you calibrated the voltage and current for MP? What is the mah reserve set for and battery size?
I've used battery FS several times, no problems.
got another violent crash today... Again, due to battery failsafe which triggers land. My quad is 3 feet above the ground when the failsafe kicked in..Violently, the quad hit a wall and crashed into the ground. As I was using CF props, the impact of the crash was relayed into the motor shaft. the shaft broke! Good thing I have spare motors in my box.
The same problem which I noticed before with battery failsafe triggers, the quad will drift instead of landing vertically..This time, I was not able to switch modes to stabilize...so it crashed.. Luckily, it was just the motor, and the prop attached to the motor, were damaged. aside from that, the quad is fine.
I replaced those parts and tested again to fly, but this time, battery failsafe is disabled. It triggered battery failsafe, but this time it did not land, only beeps and led indications. THen I landed the quad manually, safer than the land triggered by battery failsafe.
I checked on MP the voltage reading of the 3dr power module. There was no problem with the readings, it was accurate and reads the same value as my digital multimeter. I see an issue with autolanding due to battery failsafe, or is it just on my case..
Does anyone have this issue?
Hi, this day install the 3.2 version on my Y6 in an original Pixhalwk, and I see the horizon is tilted to the right, I've calibrated 6 times the accel and always remains the same.
I take a chance to fly well, and takes flight always right.
With trim and sub trim could correct it. But when I switch between modes increases the inclination and when landed the horizon is completely horizontal.
Sorry for my English.
Thank you so much for your help guys.
Works great now. My configuration was LED_Mode,71 with arming led connected to A5.
I also posted the same question the other day but already deleted it. I found that the LEDs and buzzers are active by default
A4 -motor led
A5 -buzzer
A6 -gps led
A7 -arming led
Led connected on A4 will be steady upon arming, and will blink of battery fail safe was triggered. The Same goes to led on A6, failsafe or gps lock loss will make it blink.
The good thing about this is that you don't need to configure anything on MP, just plug the leds and buzzer and it should work.
