  • Have you figured out how to fix this? I am running into the same problem! :-(
  • Anybody compiled and upload arducopter with this new arduino 1.0
    I've found two file have different name under arduino 1.0
    1. The WProgram.h file, which provides declarations for the Arduino API, has been renamed to Arduino.h.
    2. The wiring.h header file is now called wire.h
    I changed the names and ran into this.
    There is a change in the type returned by some functions
    The write(), print(), and println() functions in Stream now return a   size_t (instead of void). This indicates the number of bytes actually   written by the function. Any classes that inherit from Stream will need   to change accordingly. Additionally the write(str) function has been   given a concrete implementation – it calls write(buf, len) - so   sub-classes don't need to (and shouldn't) implement it.
    this is the output of verify I get at this point
    -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\Arduino_Mega_ISR_Registry -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\APM_RC -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_GPS -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\Wire -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\SPI -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\DataFlash -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_ADC -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_AnalogSource -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\APM_BMP085 -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_Compass -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_Math -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_InertialSensor -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_IMU -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_PeriodicProcess -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_DCM -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\APM_PI -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\RC_Channel -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_RangeFinder -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_OpticalFlow -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\ModeFilter -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_Relay -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\GCS_MAVLink -IC:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\memcheck C:\Users\Burt\AppData\Local\Temp\build6408716493749062620.tmp\ArduCopter.cpp -oC:\Users\Burt\AppData\Local\Temp\build6408716493749062620.tmp\ArduCopter.cpp.o
    In file included from ArduCopter.cpp:50:
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\FastSerial/FastSerial.h:119: error: conflicting return type specified for 'virtual void FastSerial::write(uint8_t)'
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
    In file included from ArduCopter.cpp:69:
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_DCM/AP_DCM.h: In constructor 'AP_DCM::AP_DCM(IMU*, GPS*&, Compass*)':
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_DCM/AP_DCM.h:128: warning: 'AP_DCM::_health' will be initialized after
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_DCM/AP_DCM.h:87: warning:   'float AP_DCM::_kp_roll_pitch'
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\AP_DCM/AP_DCM.h:24: warning:   when initialized here
    In file included from ArduCopter.cpp:71:
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\RC_Channel/RC_Channel.h: In constructor 'RC_Channel::RC_Channel(uint16_t, const prog_char_t*)':
    C:\Users\Burt\arduino-1.0-windows\arduino-1.0\libraries\RC_Channel/RC_Channel.h:107: warning: 'RC_Channel::_high' will be initialized after
