Here are some brief details:
KDA20-22L motors, Turnigy 30A ESC's converted to I2C, APC 10 x 4.7 props, UBEC, GWS RX8 receiver, 10mm sq aluminium frame with pcb central hub and mounting plates
RC1 code modified to add I2C motor control and mixertable for controlling 8motors. ArduOktoKopter.zip
Peter
I am not sure where my mixertable came from as I have been reading Aeroquad and Redfox code and taking bits from each. There was also a thread on the Aeroquad frum about mixertables that I found and used.
@Steve
I don't think there are enough PWM outputs from the APM to drive 8 ESC's so the alternative is I2C or one of the other fast pwm prtocols that are being trialled.
Peter
I'm experimenting with a quad rotor using the APM+Oilpan and completely custom frame. Using carbon fibre for the arms. There was plenty extra so before starting the build I did some testing. I've found the non woven fibre splits, tears and twists unless the drill bit is < mill.
However I had great success using a Dremel and diamond taper bit after first drilling a < .5mm pilot hole. Hot knife through butter as they say.
One thing to keep in mind, is how to mount the arms to the body, and how to mount the motors. I found crushing the arms was very easy. One idea which I'll explore later is filling the arms with glue or some other none compressive material, but only where high compressions are applied (screw holes) to the arms.
Can I use Carbon fiber square tube 10mm x 10mm inner 8.5mm for construction of the arms
http://cgi.ebay.com/Carbon-fiber-square-tube-10-x-10-x-8-5-x1-000mm...
and carbon fiber plate 4 mm thick to make main frame to achive better weight/payload ratio?
Also... Are there any stronger ESC's that can be converted to I2C.. in a 40A range?
Kindest regards.
Eugen
Peter
Great job! What is the max payload of your oktokopter? Did you test it?
1
2
3
of 3 Next
