- All the features of ArduPilot 2.0 plus...
- Supports XY sensor in diagonal postion
- Requires Z sensor [UPDATE: FMA is no longer carrying those. While we sort out alternative sources, you can buy them from Dean Goedde for $40 (scroll down for price list)
- Controls throttle if airspeed sensor is attached via the ArduPilot expansion board.
- Supports desktop setup utility for waypoints and autopilot settings. (Waypoints are no longer manually entered in the code. They can only be entered with this utility.)
- Last version of the code to support the original ATMega168-based board. Future versions will require the new ATMega328-based board.
- Field setup procedures are here
- Get it here
- Add waypoints manually; utility displays them on Google Maps
- Set max altitude, speed, circle radius
- Set elevator, aileron/rudder trim
- More features coming
- Get it here ("ArduPilotConfigUtility")
- Requires free Labview runtime engine and serial drivers (install both. Note: if you've already installed Lego's Mindstorms NXT software you may find you've got a driver conflict, because it's based on LabView, too. Uninstall the Mindstorms software first.)
- Works with Xbee wireless modules
- Displays real-time attitude, speed, altitude, current waypoint, heading, distance to next waypoint, etc
- Displays real time position on Google Earth
- Get it here
- Source code is here
How do I copy up this code and where?
-tychoc
I think tychoc was going to do it but have not heard back from him... [\QUOTE]
Sorry, work caught up with me and I haven't had time to follow this site. I'll try to get to it this week. Where do I post the exe?
-tychoc
This diagram was posted earlier:http://diydrones.com/profiles/blogs/ardupilot-shield-assembly
Also, search for "ArduShield" in search box above and you get a tutorial.
Fred
