  • Steve, this seems to be happening to a lot of people. My fix was to just assume it has written. Then delete the waypoints out of the utility and hit read. See if it will read back the waypoints anyway. It's my belief that there is something wrong with the "Something's wrong" output in some cases. FWIW I use the 3.3 FTDI.
    Steve:
    If you are using the 5V FTDI from SparkFun it may not work...
    If you send me your 5V FTDI programmer i will send you my SparkFun FTDI 3.3V version for free (i don't like it) this works fine with ardupilot. I need your version to be 100% sure it is not working..
  • this is my final attempt at getting the 5v sparkfun ftdi to work.. I have spent so much time getting the same errors... is anybody using this ftdi cable with success that can possibly help me?
    I can upload code to the board and get this
    Binary sketch size: 14432 bytes (of a 30720 byte maximum)
    so I figure i have the code uploaded... now I go into the config utility and select the com which is 21 and I select write I get
    "Somethings wrong"
    which does not help me much so I hit read and get
    "I can't read it"
    has anyone had this happen to them? I have the "set rts on close checked" I can see the gps light go out so the sheild is working properly and turning the gps off.... I am uploaded 2.2.2 btw.
    This is my last effort then it's getting packed up untill my ftdi arrives and I can try again.
  • well you're very welcom Tom,
    it's helping me as well!
    i'm waiting for the z sensor to be available to do some more trial and post the result here.
    my only fear is to post too much ;)
    Ah. This is new I'm 2.2. I'll update the manual.
    The flashing st LED means that the loop is running fine.
    Matt,
    I don't have a board in front of me (I'm travelling) so can't check. Is everything connected as usual (RC, GPS, shield)?
  • Thanks but the flashing stat light is not mentioned there, that's why I asked here.
  • I had installed 2.2.2 yesterday, and now when I power up my board I get a constantly flashing status light.
    What does this mean?
  • Fefenin,
    Thanks for posting your findings. It helps us who are still a bit behind in assembly and testing.
    For those of us still bulding ArduPilot and those who are already done, a general comment:
    If I may say so, since at least 200 ArduPilots were sold already, those of you who have already managed to prefect your planes and the code, and you noticed some issues that may help others in their efforts, please post it. Yes, we all need to put in honest and hard work in pursuit of this project. Also there is the challenge of overcoming difficulties. However, inadvertedly errors or guidance that may not be clear to all of us will surface, and if you would share your experience with others in overcoming them, that would help the rest of us stay on the right path.
