3689462974?profile=originalSo I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
3689463094?profile=original
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the  router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
3689463151?profile=original
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
3689462999?profile=original
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
3689463160?profile=original
3689463274?profile=original
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
3689463229?profile=original3689463317?profile=original3689463299?profile=original3689463186?profile=original 3689463358?profile=original
  • @John I had telemetry, and a GoPro camera, but no FPV.
  • I'm using xbee 900 with a 19dB patch antenna that gives me 10km range. I only use xbee as I had them already
  • @Rick
    Just out of curiosity, did you have telemetry or FPV for that flight?
  • @Rick m Much appreciated sir! And many thanks for jumping in here from my comments on you tube, I love living in the future. Hopefully I can get back in time today to try 'em out otherwise it will have to wait till Monday or Tuesday. Toby super fantastic man. Do you have telemetry if so what are you using XBess or 3DR? Once again thank you gentlemen.
  • rick m at 4:09 shadow of plane looks close
  • reposting the video
  • Here's my current setup:
    setup] show
    Radio
    CH1: 1180 | 1500 | 1821
    CH2: 1177 | 1500 | 1807
    CH3: 1103 | 1104 | 1906
    CH4: 1499 | 1500 | 1500
    CH5: 1499 | 1500 | 1500
    CH6: 1499 | 1500 | 1500
    CH7: 1499 | 1500 | 1500
    CH8: 972 | 2037 | 2037
    Batt Mointor
    Monitoring volts and current
    Gains
    servo roll:
    P: 0.700, I:0.010, D:0.000, IMAX:500
    servo pitch:
    P: 1.000, I:0.000, D:0.002, IMAX:1000
    servo rudder:
    P: 0.000, I:0.000, D:0.000, IMAX:0
    nav roll:
    P: 0.600, I:0.000, D:0.005, IMAX:500
    nav pitch airspeed:
    P: 1.000, I:0.005, D:0.000, IMAX:1000
    energry throttle:
    P: 0.800, I:0.030, D:0.000, IMAX:50
    nav pitch alt:
    P: 0.650, I:0.000, D:0.000, IMAX:500
    Crosstrack
    XTRACK: 80.00
    XTRACK angle: 3000
    Throttle
    min: 0
    max: 100
    cruise: 60
    failsafe_enabled: 0
    failsafe_value: 950
    Flight modes
    Pos 0: Auto
    Pos 1: Auto
    Pos 2: FBW_A
    Pos 3: Stabilize
    Pos 4: Stabilize
    Pos 5: Manual
    IMU
    Gyro offsets: 0.97, -0.67, -0.04
    Accel offsets: -0.15, -0.04, -0.79
    Compass: ??
    disabled
    Mag Declination: 0.0000
    Mag offsets: 0.0000, 0.0000, 0.0000
    Raw Values
    FORMAT_VERSION: 12
    SYSID_SW_TYPE: 0
    SYSID_THISMAV: 1
    SYSID_MYGCS: 255
    SERIAL3_BAUD: 57
    KFF_PTCHCOMP: 0.200000
    KFF_RDDRMIX: 0.500000
    KFF_PTCH2THR: 0.000000
    KFF_THR2PTCH: 0.000000
    MANUAL_LEVEL: 0
    XTRK_GAIN_SC: 80.000000
    XTRK_ANGLE_CD: 3000
    ALT_MIX: 1.000000
    ARSPD_RATIO: 1.993600
    ARSPD_OFFSET: 2832
    CMD_TOTAL: 7
    CMD_INDEX: 7
    WP_RADIUS: 40
    WP_LOITER_RAD: 80
    FENCE_ACTION: 0
    FENCE_TOTAL: 0
    FENCE_CHANNEL: 0
    FENCE_MINALT: 0
    FENCE_MAXALT: 0
    ARSPD_FBW_MIN: 8
    ARSPD_FBW_MAX: 20
    THR_MIN: 0
    THR_MAX: 100
    THR_SLEWRATE: 0
    THR_FAILSAFE: 0
    THR_FS_VALUE: 950
    TRIM_THROTTLE: 60
    FS_SHORT_ACTN: 0
    FS_LONG_ACTN: 0
    FS_GCS_ENABL: 0
    FLTMODE_CH: 8
    FLTMODE1: 10
    FLTMODE2: 10
    FLTMODE3: 5
    FLTMODE4: 2
    FLTMODE5: 2
    FLTMODE6: 0
    LIM_ROLL_CD: 4000
    LIM_PITCH_MAX: 1500
    LIM_PITCH_MIN: -2500
    TRIM_AUTO: 0
    SWITCH_ENABLE: 1
    ELEVON_MIXING: 1
    ELEVON_REVERSE: 0
    ELEVON_CH1_REV: 0
    ELEVON_CH2_REV: 1
    SYS_NUM_RESETS: 105
    LOG_BITMASK: 382
    LOG_LASTFILE: 0
    RST_SWITCH_CH: 0
    TRIM_ARSPD_CM: 1500
    MIN_GNDSPD_CM: 0
    TRIM_PITCH_CD: 0
    ALT_HOLD_RTL: 10000
    ALT_HOLD_FBWCM: 0
    GND_TEMP: 26
    GND_ABS_PRESS: 101820
    MAG_ENABLE: 0
    FLAP_1_PERCNT: 0
    FLAP_1_SPEED: -1
    FLAP_2_PERCNT: 0
    FLAP_2_SPEED: -1
    BATT_MONITOR: 4
    VOLT_DIVIDER: 4.127115
    AMP_PER_VOLT: 13.661200
    INPUT_VOLTS: 4.680000
    BATT_CAPACITY: 4400
    INVERTEDFLT_CH: 0
    SONAR_ENABLE: 0
    ARSPD_ENABLE: 1
    RC1_MIN: 1180
    RC1_TRIM: 1500
    RC1_MAX: 1821
    RC1_REV: 1
    RC1_DZ: 30
    RC2_MIN: 1177
    RC2_TRIM: 1500
    RC2_MAX: 1807
    RC2_REV: 1
    RC2_DZ: 30
    RC3_MIN: 1103
    RC3_TRIM: 1104
    RC3_MAX: 1906
    RC3_REV: 1
    RC3_DZ: 3
    RC4_MIN: 1499
    RC4_TRIM: 1500
    RC4_MAX: 1500
    RC4_REV: 1
    RC4_DZ: 30
    RC5_MIN: 1499
    RC5_TRIM: 1500
    RC5_MAX: 1500
    RC5_REV: 1
    RC5_DZ: 0
    RC5_FUNCTION: 0
    RC5_ANGLE_MIN: -4500
    RC5_ANGLE_MAX: 4500
    RC6_MIN: 1499
    RC6_TRIM: 1500
    RC6_MAX: 1500
    RC6_REV: 1
    RC6_DZ: 0
    RC6_FUNCTION: 0
    RC6_ANGLE_MIN: -4500
    RC6_ANGLE_MAX: 4500
    RC7_MIN: 1499
    RC7_TRIM: 1500
    RC7_MAX: 1500
    RC7_REV: 1
    RC7_DZ: 0
    RC7_FUNCTION: 0
    RC7_ANGLE_MIN: -4500
    RC7_ANGLE_MAX: 4500
    RC8_MIN: 972
    RC8_TRIM: 2037
    RC8_MAX: 2037
    RC8_REV: 1
    RC8_DZ: 0
    RC8_FUNCTION: 0
    RC8_ANGLE_MIN: -4500
    RC8_ANGLE_MAX: 4500
    HDNG2RLL_P: 0.600000
    HDNG2RLL_I: 0.000000
    HDNG2RLL_D: 0.005000
    HDNG2RLL_IMAX: 500
    RLL2SRV_P: 0.700000
    RLL2SRV_I: 0.010000
    RLL2SRV_D: 0.000000
    RLL2SRV_IMAX: 500
    PTCH2SRV_P: 1.000000
    PTCH2SRV_I: 0.000000
    PTCH2SRV_D: 0.002000
    PTCH2SRV_IMAX: 1000
    ARSP2PTCH_P: 1.000000
    ARSP2PTCH_I: 0.005000
    ARSP2PTCH_D: 0.000000
    ARSP2PTCH_IMAX: 1000
    YW2SRV_P: 0.000000
    YW2SRV_I: 0.000000
    YW2SRV_D: 0.000000
    YW2SRV_IMAX: 0
    ENRGY2THR_P: 0.800000
    ENRGY2THR_I: 0.030000
    ENRGY2THR_D: 0.000000
    ENRGY2THR_IMAX: 50
    ALT2PTCH_P: 0.650000
    ALT2PTCH_I: 0.000000
    ALT2PTCH_D: 0.000000
    ALT2PTCH_IMAX: 500
    COMPASS_OFS_X: 0.000000
    COMPASS_OFS_Y: 0.000000
    COMPASS_OFS_Z: 0.000000
    COMPASS_DEC: 0.000000
    COMPASS_LEARN: 1
    COMPASS_USE: 1
    COMPASS_AUTODEC: 1
    SR0_RAW_SENS: 0
    SR0_EXT_STAT: 3
    SR0_RC_CHAN: 3
    SR0_RAW_CTRL: 0
    SR0_POSITION: 3
    SR0_EXTRA1: 10
    SR0_EXTRA2: 10
    SR0_EXTRA3: 3
    SR0_PARAMS: 0
    SR3_RAW_SENS: 0
    SR3_EXT_STAT: 3
    SR3_RC_CHAN: 3
    SR3_RAW_CTRL: 0
    SR3_POSITION: 3
    SR3_EXTRA1: 10
    SR3_EXTRA2: 10
    SR3_EXTRA3: 3
    SR3_PARAMS: 0
  • Here's one of our videos. Can't remember if this was the no-wind day (I think it was): https://vimeo.com/41881013. I'll try to post the track of our bad flight, if I can find it.
  • @Rick, I have the same problem, the PID's I posted above work awesome in no wind, but on a slightly windy day today it was all over the place. Winding up the gains and it started hunting. So I think these PIDs need some more work.
    Here is some video of the flight in no wind this morning, it was so amazingly stable that it blew my mind
    trans.gif?width=420
  • Nice call, I went back to the ArduPilot manual and READ the instructions and I did have manual trim set on my radio.  Do I set radio to neutral, calibrate and then go back to manual to set my trims in manual? Whats your flight weight that your testing at and your motor specs. Looking forward to your updated PIDs and getting this thing in the air this weekend. Thank you.
