3689462974?profile=originalSo I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
3689463094?profile=original
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the  router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
3689463151?profile=original
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
3689462999?profile=original
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
3689463160?profile=original
3689463274?profile=original
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
3689463229?profile=original3689463317?profile=original3689463299?profile=original3689463186?profile=original 3689463358?profile=original
    Can you share your pid settings? Are they working fine?
    Anyway, after 4 months with this topic can someone post some good parameters? :)
  • I'm still looking at all the folding options out there, but it has survived 6 flights now !
  • looks good no folding prop?
  • Went mad with a spray can....
  • 3692533902?profile=original3692533693?profile=original
  • Drop me your email and i will forward you the file im using.
  • So Im only hrs off its maiden. Where exactly can I find the PID Parameters to download? or do I type them manually in from the posted picture near the start of the thread?
  • sorry to hear that also but let us know if you find out what happend
  • Unfortunately, we had grown complacent in our UAV's reliability. We've done a dozen flights without incident, and so weren't paying very close attention to the telemetry showing the gradual descent. Even if we had had a joystick, it's not clear it would've helped, even if we had been paying attention.
  • Sorry to hear Rick,
    This is the sort of situation where a joystick via telemetry MAY be useful...I am including one in my setup and I intend to do a write-up on how that goes.
