We are tring to build a FPV Rover combining a logitech racing wheel with an RC Car for an FPV platform.
However we are having some problems with the latency and tracking of the steering wheel input.
- I have checked the RC inputs using MAVlink and checked that the rc override was working fine
(The racing wheels seem to be in sync with the rc inputs)
- The steering does respond but is rather slow in response and does not move to the ends
- I checked this using the my turnigy 9x receiver but there was no problem with the steering, steering responds well
-> to conclude,
The RC inputs seem to change properly commanded by the racing wheel but when steering with mavlink latency problem and tracking problem comes in. There is no problem when controlling with the rc transmitter
Does anybody have an idea to fix or go around this problem?
Rover
-Ardurover v2.47
-HKPilot Mega 2.7
Ground Station
-Mission Planner
-Logitech Wingman Formula Force GP
  • It was set up over IP connection through an access point plugged into a laptop with ethernet, let me know if you need help!
  • I have had great results using a xbox remote and a Wifly
    https://www.sparkfun.com/products/10822 insted af the 3dr telemetry
  • if you have a joystick laying around try that also try taking down with drivers in windows and restart the pc and see if that helps also you have connected it via usb i tried to do the same with a telemetry with a joystick for quad. no rudder XD
  • Was the wheel calibrated properly in windows?
  • Does it do the same thing with different joysticks?
