ArmQuad stable mode first flight
This is my experimental quadrorotor. In this flight I'm trying the stable mode with the accelerometer.
ARM 7 32bit LPC2103 a 60Mhz ( Coridium ARMmite PRO )
ITG-3200 Triple-Axis Digital-Output Gyro, 16bit, digitally-programmable low-pass filter
BMA180 Triple Axis Accelerometer, 14Bit, Programmable integrated digital filters
ESC: PWM at 495Hz
R/C RECEIVER: PPM composite signal, 8 Channel
Greetings, Danilo
  • I like the choice of hardware, basic or c its all the same. I will follow your blogs
  • @Morli, thank You. Currently is in beta, If I decide to release it, I have to make sure everything works before releasing.
    @Brad the motor are Keda 20/22L 17A with EPP 1245 propeller
    @TimL The software is written in BASIC programmed with the Coridium tools, however in the future I think go to C to make better use of hardware and software resources
  • Seems very smooth. Which language/tools have you used to program with?
  • What motor/prop combination are you using? It's much quieter than most quadcopters I've worked with. Very nice.
  • Thank You Roberto, Greetings to FoxTeam ;-)
    Great Job Danilo :)
