Hi guys,
Have some pictures of the AUAV-X1 board with connectors - top side and bottom side. Also some scopes applied - input voltage from 4V to 8VDC and different loads - 0.5A and 1A.
Some picture explanations - from top to bottom:
TPS63061_4V_1A
TPS63061_5V_0.5A
TPS63061_7V_1A
TPS63061_8V_0.5A
The temperatures are respectively - 34.5 deg C of the TPS63061, 31 deg C of the Schottky diode, 28 deg C of the inductor. They remain stable within an hour measurements. The output voltage is perfect stable - 5.05VDC. The LDO output voltages are between 3.305 and 3.312VDC respectively.
Best regards
Nick
Hi Aaron,
I've been thinking a lot over the flexi board idea and I think it has some cons as follow:
When locating the sensors over the flexible board, you are lowering the total mass of the sensor group, thus making it vulnerable toward the higher vibration frequencies. Lower the mass, higher the resonant frequency.
Maybe better is to have some bigger mass attached under the sensor group, then this combination placed on a silicone rubber damper. Also the width of the trace zone between the main board and the sensor plate should be as narrow as possible, to be as flexible as possible, thus reducing the conducted vibrations from the main board.
It seems it is not so easy to isolate the sensor group from vibrations at all. I still have no conclusion which one is better ( light weight mass vs heavy mass ). More, the ST set and MPU6000 have a bit different mechanical resonant frequencies - ST is about 20kHz, while the MPU6000 has a MRF 27-33kHz depending on axis.
All proposals and advices are highly appreciated!
Nick
So, we don't need the microIMU boards at all....the IMU ICs will be soldered directly over the larger zone of the flexible board.
Btw, the blue zone ( Chips ) should not be there. From STM32F4 up, the order is: heatsink, anti shock material, flexible board, IMU ICs. The problem is that the anti shock material will hinter the heatsink from dissipating the heat.
+ some addons to your idea:
As STM32F4xx is the main heat dissipation device, if we can find out how to combine a small heatsink with an anti shock plate, we could achieve the perfect solution.
More, having much larger flexible board, we can combine the ST set with either MPU6000 or the newer one MPU9250.
Hi Aaron,
This is great idea. It could solve all our problems with the dimensions of the IMU.
As I understand your idea, the flexible board will have a connector at one side and all the IMU ICs soldered on the larger non vibrating surface? That's really cool!....and feasible. The only thing which has to be solved is the design of the transition between the mainboard and the flexible board.
Best regards
Nick
Hi guys,
I am writing this post asking for understanding and apology.
We have to delay the AUAV-X1 project again because the stacking of a such miniature boards as IMUs is almost impossible.
For the moment we could offer 3 IMU versions - ST set ( L3GD20H + LSM303D ) or MPU6000 or MPU9250.
As the MPU9250 IMU uses the same pinouts as of the ST set, the code needs some mods.
Redesigning and manufacturing a new microIMU combo ( ST set + MPU6000/MPU6500 ) will take some time.
If some of you prefer refunding their preorders, it's o.k. We could also either compensate the preorders for stacked IMU with ACSP1 or by refunding the MPU6000 addon.
Thanks in advance for your understanding.
Best regards
Nick
The second one seems perfect but both do look very good. Can't wait for your board to have some working code... Will be awesome for gliders!
i wish it will be ready available with arducopter code inside rapidly :)
you board seem to be very good
....or this...
What about this?
Hi Cronselaar,
I'll highly appreciate your help with color choice. I'll change them to be most comfortable to the users.
Please advice.
1
2
3
4
of 4 Next
