Here a video of an autonomous flight with a Maxi Swift flying wing fully piloted by the firmware ArduPlaneNG v2.x R5 with an All In One Pro (AIOP) full IMU board.This is a porting of the ArduPlane v2 (v2.4+v2.5) firmware and special addons and improvements for the AIOP board that I have added.
The wind was 15 km/h gusting 22 km/h. The flight was very stable in spite of the gusty wind conditions.
3689473600?profile=original
3689473686?profile=original
Setup:
  • IMU board: All In One Pro (AIOP) v1.0 from CRIUS,
  • GPS: Crius CN-06 (Ublox NEO-6)
  • AirSpeed sensor: MPXV5004DP (from a old ardupilot one shield)
  • firmware ArduPlaneNG V2.x R5, porting of the ArduPlane v2 + special addons for the AIOP v1 IMU board by JLN
3689473718?profile=original
Flying Wing: Maxi Swift from MS Composite (1m40 wingspan)
  • brushless motor Spitz 30 850 kV, 360W with a propeller GWS 10x4.5
  • Lipo: 3S EVO25 2650 mAh
  • Receiver: Turnigy 9X8C v2
  • Transmitter: Turnigy 9x with Er9x firmware
3689473701?profile=original
More infos at: http://diydrones.com/profile/JeanLouisNaudin
  • I solved a problem with the channel mixer elevon. But still I can not find the file " # include  "APM_Config_EasyStar2.h " !!!  Help me, please !!!!
  • Hello Jean Louis and everybody!
    Help me please with my problem. I've got the flying wing and AIOP V2.I loaded firmware ArduPlaneNG V2.x R5, but my elevons works uncorrectly - one elevon works only as roll, another elevon as picth ( in mode "STABILIZE"). In "MANUAL" works well. All settings of the transmitter such as recommended by the Jean Louis.I'm trying to use " # include  "APM_Config_EasyStar2.h ", but I  got a wrong message - no such file... and I can't find this file anywhere... Where I can find this file? Or, am I doing something wrong?
  • Jean Louis,
    Everybody,
    in fact my atmega seems to have its output connected to the pin5 dead.
    is it possible to choose (re adress) outputs to use functionnal outputs?
    Thanks a lot for your help
  • i ve modified that :
    #define APM1_MOTOR_TO_CHANNEL_MAP CH_10,CH_2,CH_3,CH_4,CH_7,CH_8,CH_1,CH_11
    but seems to be not sufficient...
    coult show mw where and how do?
    Thanks a lot
    Hello Mathieu,
    You may change the motors mapping in the library itself. Look at the file AP_Motors.h in the AP_Motors library.
    I hope this will help you.
    Regards, Jean-Louis
  • The pin 5 of my CRIUS AIOP V1.1 seems to be dead, i have 4.4volts (signal3ground vs 2.2volts for the other pin)
    How can i re allocate motor pin?
    the pin 5 is always used in different config (tri, quad, plane..) :'(
    thanks for your help
  • well with PID_MaxiSwift_APNG2xR6.param  :)
    Hello Ivan,
    You may use:
    #include "APM_Config_EasyStar2.h
    and then load the param file:
    MaxiSwift_PID_ArduPlane273-xp1.param
    look at this link for more infos:
    https://github.com/jlnaudin/x-drone/wiki/x-drone:-MaxiSwift,-missio...
    Regards
    Jean-Louis
    https://raw.githubusercontent.com/jlnaudin/x-drone/master/parameter_files/MaxiSwift_PID_ArduPlane27…
  • What to choose for flying wing in ArduPlaneNG2xR5.
    # include "APM_Config_Thp.h"
    / / # include "APM_Config_HILmode.h"
    / / # include "APM_Config_EasyStar2.h"
    / / # include "APM_Config_Cularis.h"
    / / # include "APM_Config_ASW27.h"
    / / # include "APM_Config_MAJA.h"
  • hello,
    i have the board from hobbyking flashed with ArduPlaneNG2x. and i have a few questions:
    1. there are two constant red leds in the center of the fc, what do they indicate?
    2. when i power it up, led a (the left one) blinks twice, and only after that i get the boot sequence leds. what does
    the blinking led tell me?
    3. i got minimosd connected to the board (s03), but the board comunicates with it succesfullly only when its pwered by a ubec. when i power it using my speed controller - no telemetry feed.  what am i doing wrong?
    iv'e been looking everywhere for answers, with no luck so far:(
    please  help
