For my FPV camera, I have this:
I have a 2.4 wireless Cam set up called the Draganfly Eyecam.
Specifications:Camera and transmitter weight: only 9 gramsCamera and transmitter size: 15mm x 22mm x 32mm (5/8" x 7/8" x 1 1/4")Camera Lux: <3 @ f1.2Camera Auto Electronic Exposure of 1/60 to 1/15000 sec. w/ Auto Gain & White BalanceCamera Signal to Noise Ratio:48dB365K (PAL) camera pixel resolutionWireless Transmission Range: 300M (1000'), Line-Of-SightTransmitter RF Output Power: EC R&TTE Compliantreceiver Video Input/Output: 1Vp-p/75 ohmSee More Info Here.I plan to use these as my first Goggles. They are cheap but should work fine for now.Specifications:Video input format: NTSC/PAL/SECAM automatic selectionVirtual Image Size: 50 Inches as seen from 6 ½ feetResolution: 230,000 pixels per LCDColor Depth: 24-bit inputViewing Angle: 26 degrees diagonalVideo Input: Composite AVAudio: Dual-channel stereoPower Supply: Built in 480mAH rechargeable batteryPower Consumption: <0.45WNet Weight: 4.2 Oz (119g)
More info here
Thats where I am so far. Yeah I know I have a long way to go!I found this member of diydrones today! I was really excited to see he was using the same basic platform.He is doing exactly what I want to do!!!!!!!!! How cool. Check out his project and you will see what I am trying to accomplish. As I progress, I will update this post. Feel free to drop tips and advice - they will be much appreciated.
May i ask... What is the status of your build? Have you used it at all and how well does it work?
Gerrit
PAL and NTSC are competing video standards from different parts of the world.
If your unit works, then its NTSC and therefore not an issue... sorry to complicate things.
Although the glasses are input switchable, make sure the camera NTSC.
http://www.rcgroups.com/forums/showthread.php?t=1131712
