  • People post and forget. It's easy to get motivated to do one write up after a project completion but hard to actually slow down and help other.
  • If queries remains open for months then what is the use of your starting this blog ?
  • Hi F5PQL ! mine came and the code is running fine in the module. Now I need wiring diagram or something like that which may help.
    cheers !
    Rana
    You have to move all the stuff from Ardustation3 "libraries" to your local "libraries" (usually in your Arduino folder in Documents)
  • I would like to compile the Ardustation3 code but am lost as there seems to be VisualMicro files in the repository. Please could someone give me a steer - I am using the Arduino IDE.
    Peter
  • Hi F5PQL !
    Requested, to pls share the complete schematic / wiring detail and assembly instruction of Ardustation 3
  • Hi ! is the link you have provided, is the same part you have purchased and using for this project ?
  • Hi ! Thanks purchased the one you sent link for. My order #(271019848784).
  • Many seller on Ebay.com for example :
    SainSmart Mega2560+3.2" TFT LCD Shield+Touch Screen SD Reader for A...
