2 Calibration of the pitot tube and amplifier stage (sensor MPX2010) Posted by Armando on July 4, 2011 at 2:18pm WIND TUNNEL Amplifier StageResults of calibration in wind tunnel E-mail me when people leave their comments – Follow
I did the same using the speedway as wind tunnel with an arm out of the car with a stand to take sensor out of the turbulence in a dead wind day :D
similar curve results with 5004 sensor, up to a value it sense very little, than it is almost linear.
now can't remember data but if someone needs it I can provide the excel graph.
Thanks for your comments
All comments are welcome
The MPX2010 Datasheet .
http://www.freescale.com/files/sensors/doc/data_sheet/MPX2010.pdf
Voltage Output versus Applied Differential Pressure
The output voltage of the differential or gauge sensor
increases with increasing pressure applied to the pressure
side (P1) relative to the vacuum side (P2). Similarly, output
voltage increases as increasing vacuum is applied to the
vacuum side (P2) relative to the pressure side (P1).
I reproduced the experiment of this thesis (Speed Sensor)
http://www.stanford.edu/~abusleme/files/Control%20Difuso%20de%20Veh...
Page 144 to 155.
The knee seems to indicate the pressure threshold where the air through the pinhole starts to excite the sensor.
Also, this barometric sensor is measuring pressure (not airspeed), which is related to the square of speed.
It is not really a pitot, as the total pressure is measured here, and not a differential one, like in a pitot.
what kind of ADC converter is used?
did you used this formula : http://www.grc.nasa.gov/WWW/K-12/airplane/pitot.html
Thanks.
Hello, do you make something like this?
Sorry, it's in french.
http://www.flashrc.com/jeti/6485-capteur_vitesse_duplex_mspeed.html
