Compatible at 100% of the purchases !
We finally have some 6-Position mode switch DIY kit, compatibility info for new users !
Tested compatible Transmitters:
- Turnigy 9x 7 Users
- Turnigy 9x ER9x Firmware 4 Users
- Futaba T10CG (removing the CamPac unit) 1 User
- Futaba T6J (physical modification needed) 1 User
- FlySky FS-TH9B 1 User
- FlySky FS-TH9X 3 Users
- Hitec Aurora 9 1 User
Additional user comments received:
> The switch works just like a dream. Thank you for a perfect solution !
> I tried out the switch and definately feel that it is worth my effort to install as now I can use 6 flight profiles and easily switch between them.
> I found the installation easier then soldering on a deans connector, and with my intermediate soldering skills I was able to complete the installation.
> Using this switch has been flawless. Once calibrated I have never experienced any failures with the hardware. It has come to the point that I trust it without a second thought. It has been so essential to my radio setup that I cannot imagine using an APM2 without it.
> Very Easy to set up. I am very pleased with the switch. And easy to mount when I can buy the parts in a kit and with instruction.
> installation was easy. i mounted mine in place of the hover pitch pot. i had to file the body of the "ele" switch a little to get it to fit, but it did -FlySky FS-TH9X
> It surely does make life easy... The big advantage is that now I have all the modes on just 1 switch. No need to look around for combination of 2 different pots...
> i am using it for my NAZA GPS and it made my life easier, one is used for flight mode (Manual/Attitude/GPS/Fail Safe(RTH)) and one for Intelligent Orientation Control (IOC) (Off/Home Lock/Course Lock)
> Extremely easy to install, even with it being the DIY version.It is perfect! I Could only use 3 modes easily before, so this is a night and day difference.
Where can i get one ?
Help us get information !
If you did not participate in the eBay survey, please comment below with your Transmitter model so more users could be aware of the compatibility !
Thank you !
USER PICTURES:
On theFutaba T10CG
The instructions does not explain how to solder the knob to the blue trimmers??
The DYI universal kit works well in my Hitec Aurora 9.
I did a similar mod (my own parts/method) to a Hitec Eclipse Tx and I didn't think it was safe without a master "enable" switch (which you may already have or counsel, IDK). This enable switch flips between Stabilize mode and the mode selected by the 6-pos switch. The point being that it's really best to be in Stabilize mode before you change to another mode. Just my opinion... I see that Auto and Acro modes are on ends of the switch travel for just this reason, they are not modes you want to "sweep past" when picking something else. Comments? Am I being overly wary?
I ordered 2 of them 2 months ago and I never received my product. I sent multiple emails to find out what the deal was and all i kept getting is it takes time in the mail. I never received any tracking number and I was very disappointed. Over 60 days later I get my money back (finally). Very disappointed purchaser. I just want them to resend with a tracking number and they refused. Just a FYI, Order at your own risk.
Do you have a guide (tutorial) to install a Futaba T10C?
