Compatibility list of the 6-Position Mode Switch
Compatible at 100% of the purchases !
We finally have some 6-Position mode switch DIY kit, compatibility info for new users !
3689481166?profile=original
Tested compatible Transmitters:
  • Turnigy 9x   7 Users
  • Turnigy 9x ER9x Firmware  4 Users
  • Futaba T10CG  (removing the CamPac unit) 1 User
  • Futaba T6J  (physical modification needed) 1 User
  • FlySky FS-TH9B  1 User
  • FlySky FS-TH9X  3 Users
  • Hitec Aurora 9  1 User
Additional user comments received:
> The switch works just like a dream. Thank you for a perfect solution !
> I tried out the switch and definately feel that it is worth my effort to install as now I can use 6 flight profiles and easily switch between them.
> I found the installation easier then soldering on a deans connector, and with my intermediate soldering skills I was able to complete the installation.
> Using this switch has been flawless. Once calibrated I have never experienced any failures with the hardware. It has come to the point that I trust it without a second thought. It has been so essential to my radio setup that I cannot imagine using an APM2 without it.
> Very Easy to set up. I am very pleased with the switch. And easy to mount when I can buy the parts in a kit and with instruction.
> installation was easy. i mounted mine in place of the hover pitch pot. i had to file the body of the "ele" switch a little to get it to fit, but it did -FlySky FS-TH9X
> It surely does make life easy... The big advantage is that now I have all the modes on just 1 switch. No need to look around for combination of 2 different pots...
> i am using it for my NAZA GPS and it made my life easier, one is used for flight mode (Manual/Attitude/GPS/Fail Safe(RTH)) and one for Intelligent Orientation Control  (IOC) (Off/Home Lock/Course Lock)
> Extremely easy to install, even with it being the DIY version.It is perfect! I Could only use 3 modes easily before, so this is a night and day difference.
Where can i get one ?
Help us get information !
If you did not participate in the eBay survey, please comment below with your Transmitter model so more users could be aware of the compatibility !
Thank you !
USER PICTURES:
On theFutaba T10CG
3689481219?profile=original
  • Dear ARHEXA, You wrote for 6 position mode switch: ■Futaba T6J  (physical modification needed) 1 User. Who is 1 user? Give the contact please!
  • You wrote for 6 position mode switch: ■Futaba T6J  (physical modification needed) 1 User. Who is 1 user?
  • I'm having trouble with this Ebay seller (from Israel). I bought and payed Jan/17. But since from, have any return of the four emails I've sent.
    Maybe I should cancel it with Paypal help. I'm sad about, they had any after sales attention, unfortunatelly.
  • You can get the modes on the Tx screen if you flash open9x
    https://www.youtube.com/watch?v=KoDTbWjwOI8
    test post
    test post
  • Is possible installing this on a futaba 6ex?
  • the selected modes for each position are setable in the sketch for the ardupilot
    AP_Config.h
    #define POSITION_1 MANUAL // the default, don't bother changing.
    #define POSITION_2 STABILIZE
    #define POSITION_3 FLY_BY_WIRE_A
    move (rearange) them to match where you prefer them on the switch
    having set the pots from low to high in increments for each position
