Configure 6 flight modes for Futaba T7CP
I bought a cheap RC Futaba T7CP on ebay, but I spent 3 days in order to understand the right configurations of switches to enable 6 flight modes.
Here, my solution. Hope useful for the community.
(I used some hints from other blogs)
1. I used SWE and SWA. SWE is a 3-position switch. while SWA is on the left and it is a 2-position switch
2. You have to set End Point, SubTrim and RT in MIX. First, set the ENDPOINT for CH5 to be 50%(UP) and 52%(DOWN). You can tune the values until the pwm value(see point 5.) are right.
3. Then, set the SUBTRIM for the GEAR (CH5) to be 100%
4. Configure a P-MIX ( I used P-MIX1) to be without offset, and with the following rates: 24% and 60% (You can switch between the rates by using the 2-position switch)
5. Exit (END button) and check the pwm values in CLI->test->pwm.
6. Configure you radio in CLI->setup->modes
NOTE: Maybe, in order to not mess the radio setup, you have first to setup radio channel: CLI->setup->radio
I attach some pictures for sake of clarity.
Regards to everyone
1. First set the endpoint for Rudder (CH5)
3689412583?profile=original
2.Then adjust the GEAR of CH5
3689412472?profile=original
4.Finally, set the mixing program.  I choose P-MIX1
3689412489?profile=original5.Set the Master and Salve Channels (I used for Master CH7 and for slave CH5). Set the 2 rates : you can switch between one and the other by toggle the A switch
3689412537?profile=original
  • ive followed this and got it pretty much right except for a bit of tuning to get all six positions perfect, but this is mixing channel 5 and channel 7 - so to enable this switch mixing im actually losing channel 7 completely? have i got something wrong in the setup or is this to be expected? frankly its hardly any improvement over the plain three position switch plus a fourth option on channel 7.
    james
  • 3692361952?profile=originalBonjour,
    Ces photos pourront je l'espere vous aider ( 7cp en 35Mhz)
    cordialement3692361862?profile=original
  • I have
    PARAM CH5-SW E
                   CH7-SW A
    P-MIX1 CH7->5
    MAS>CH7
    SLV>CH5
    It depends which physical swithes you want to use.
    Now I get 5 modes, but it's enough for a while.
  • On  programming T7C,it seems some informations missing, as:
    PARAM: CH5=>SWE? CH7=>SWA?
    PMIX1: MAS=>CH5 or CH7? and SW: A (2possibilities) or E (5 possibilities)?
    Thanks for answer...
  • I keep playing with this but cant get it right- I'm a radio novice. Is there a way to get 4 modes and still use channel 7 for set, for example, auto-level. I'm sure its obvious to someone, I'm banging my head on a wall.
  • The settings that worked for me were:
    End Point on Ch 5 Up 52 Down 39
    Sub Trim Gear +120
    Then P-Mix 1 as per the recommended settings above (60% as in the text, not 69% as in the photo).
  • Sorry, maybe late, but there is "second" round (cursor down) of P-MIX1 options, INH must be OFF(instead), then the second "round" seems to be all right P-MIX1 CH7->5
  • Hi everyone, so I have read the post over and over again, but I can only manage to get 3 position on my T7C. I just bought it so I am still finding my way arround it but I would rather stand on the shoulder of giants to see over the horizon, so please can some giants out there help?
  • Ah haaaa just realised I needed to set PARA CH5-SW>E and CH7-SW>A. Under the PARAMETR menu page 2.   this was where I was going wrong.
  • Hi,  found out regarding the offset.
    But I have another problem.
    I configured 6 modes in the CLI.
    But when I get back to the flight data, under status, the "mode" field doesnt correspond to the modes I configured in the CLI (I am connected via USB) which one of them is the correct indication of the mode?
