1 Design feedback needed - 2 Posted by Aleksei Ivanov on December 29, 2014 at 5:28pm The "balloon" around the rotors is for storage only. You can open the upper part and put up to X batteries in it.All comments are welcome. E-mail me when people leave their comments – Follow
leave the balloon and make it float
Drugs?
hmmm . I see this would need a coaxial heli swash plate as how I see it. it could use a FBL system. but the CG is got to be lower as usual to make it work.
Here's an articulated head one, top rotor does the tilt, I expect both help contain the yaw.
The designer of the Aesir project is a member here I will let him chip in if he feels like it but they had forward flight at speed issues.
http://img.bbs.163.com/new/20110129/mil/sp/spada117/798b922790bc389...
looks like it uses coanda effect and aerodinamical control elements
http://store01.prostores.com/servlet/myasianart/the-2215/Sikorsky-C...
I hereby challenge you to incorporate this into a Star Wars: Empire Strikes Back probe droid shell.
If you had the motor rod mounted to another ring that rotated 90 deg to the motor rod you could have x,y and z control. Similar to gyroscope rings.
Articulated head, not the two standard props as shown in the design......
